Old 04-09-2009, 10:15 PM   #1
5thseries
biggerthen3
E90s suck, or mine is shit.
got a 2006 e90 325i from the collection.. posted pics
ok, the driving is horrible, The run flats are super loud.. I am not sure if the tires are making the nose 100%, but during acceleration and stops.. stopping when speeds reach 50-20km/h, it gets reallllllyyy loud coming from the wheels, like a loud *RU RU RU RU RU RU RUGGG* Its louder then usual, and the wheel has a shake to it also driving, the wheel is so hard to turn, the power steering seems not to be working, i thought it would be a power assist set up, but I was told it was not...
Now question, could run flats be responsible for the loud, highly uncomfortable ride?
Now, the gears.. its a 6 speed manual.. shifting too 2nd is really weird, it feels like it notches on something before 100% entering second gear.. now still being on the gear subject.. clutch FULLY down.. it feels like it does not want to go into first gear at times, from the neutral position putting it into gear, seems you have to Force it in...
Starting the car in the morning... after turn over, you hear a clunk sound come for the engine, I have NO clue what it is..but after rpm drops to 500, (roughly) the engine pers...
These are the problems with the car, that i have experienced.. what exactly is going on with the car, and what needs to be fixed?? The car was taken to the stealership, and they said the runflats cannot be that loud.. so at this point im shitting myself/confused.. wheel alignment? ****.. ><
also, does any e90 drivers experience this?
5thseries is offline   Reply With Quote
Old 04-09-2009, 11:42 PM   #2
e36_all_out
Yes the runflats will cause that noise. Especially while under braking because there is so much more load on the front wheels while you are applying the brake. Its called cupping and because of the suspension setup on the e90's is causes a very uneven wear on inner and outer treds.
The ride that you experience to be rough is caused by the stiff side wall which makes them runflats to begin with. It feels like the car has a lowered suspension.
Best way to check is rub your hand against the tred, it will feel like a porcupine. 1 way will be smooth the other will be like going up steps
e36_all_out is offline   Reply With Quote
Old 04-10-2009, 12:32 PM   #3
1'M Seriesus
yeah the sidewalls on the run flats are extremely thick, and the can not flex like it normally would under hard racing condition.
The one tire shop in town couldn't even take them off my 1'ner, i had to get my friend at chevy dealer to take them off and put on the new Yokohama S.drives
1'M Seriesus is offline   Reply With Quote
Old 04-10-2009, 02:11 PM   #4
5thseries
biggerthen3
Thank you ^
Old 04-10-2009, 04:21 PM   #5
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
The sport package 225/255 run flats on my E90 are quieter than my non-run flat 205 snows. But noisy snows are expected- what i'm trying to say is that the run flats are not that loud. Ride quality is subjective, but even with sport package and 17's, the ride is much smoother than my 318ti with H&R sport/Bilsteins (mild drop) and 15's.
You should be able to turn the steering wheel with 2 fingers, at all times. It should not shake at any time.
If your getting the "ru ru ru" noise when braking only, it's your brakes. Previously overheated brakes will make that noise. Prolonged driving with bad alignment will also cause any tire to do that as previously posted by others, but you will see visible damage if this is the case.
Engagement of every gear should be the same.
There is no audible clunk sound from within the cabin when starting the engine. If you have the window open, you can hear the starter disengage with a click, but definitly not a clunk.
I'm almost certain your E90 was previously abused if it's displaying all the symptoms you are describing. A single track day by an inexperienced driver can cause all the things you mentioned (shaking, no power assist, noise when braking, difficulty engaging gear, difficulty starting).
Old 04-10-2009, 04:25 PM   #6
BigD
the misanthropist
BigD's Avatar
+1, I think it was a lot more than just some ham-fisted track driving. Unfortunately, this thread should have been posted before you brought the car home. It was probably an auction fix-up. Did you check its history through UVIP and carproof?
Old 04-10-2009, 07:36 PM   #7
5thseries
biggerthen3
Car proof is super clean.
Old 04-22-2009, 09:15 PM   #8
ImolaMZ3
Welcome to the world of "Run Louds" as my wife calls them. I absolutely hated them and after the second set bought some F1 GSD3's from the Tire Rack. Absolutely transformed the car. There was a service bulletin for this problem on '06's but once the miles add up you don't qualify.
As for the your other problems it doesn't sound good. My transmission shifted with one finger, no notches. Clutch engagement was smooth, never to the floor. Turn in was razor sharp. Yours is not normal.
Too bad you didn't look at mine. I had it in the classifieds on the board for a few weeks before I traded it.
ImolaMZ3 is offline   Reply With Quote
Old 05-21-2009, 03:27 PM   #9
KINKY
run flats suck.
Get a set of proper wheels and your set to go
I've also upgraded the suspension and added reinforced strut bar and sway bars, now my car corners like a BEAST.
It performs COMPLETELY different.
KINKY is offline   Reply With Quote
Old 07-21-2009, 10:21 AM   #10
MMOTION
stock RFT tires suck. when i got my E90 330xi i got 162's w/ Michelin Pilot Sports and the ride is so much better and quieter...better handling too.
MMOTION is offline   Reply With Quote
Old 07-21-2009, 11:20 AM   #11
brunp
I just changed out from 17" 225/45 R17's Continental SSR's to 18" staggered setup with Falken RT615 (so non-runflat) and the car drives smoother than the 17"s and even more so when teh 16" Bridgestones that were on the car.
Now, I am completely run-flat less as my winter tires are standard tires. I now have a sealant kit.....
Paul
brunp is offline   Reply With Quote
Old 07-25-2009, 07:59 PM   #12
automadness
your prob is where you got your car from my friend bought a caddy from there and had tons of problems with it
automadness is offline   Reply With Quote
Old 07-26-2009, 02:02 AM   #13
doogee
doogee's Avatar
I'm pretty sure BMW's are notorious for having notchy 1st-2nd shifts. Same with it not wanting to go into 1st at stops.
Dakar M3 Track Build Thread
Old 08-08-2009, 10:15 AM   #14
rocken
got mine e90 2006 and hate them further inspection showed the tires are cupped leading edge of thread is higher (taller than the trailing edge so its like a saw blade....cause? setup or lack of rotation i am told
looking for new wheels and rim save the stock 16in for winter rubber
hate the tires....so LOUD
rocken is offline   Reply With Quote
Old 08-08-2009, 10:17 AM   #15
europrince
I wouldn't buy any car from The Collection. I went there a couple months ago and every car in the show room had a noticeable layer of dust on it. If that's how you care for your cars, what kind of cars are you selling? The place was just grimey.
