Old 04-08-2009, 07:27 AM   #1
aristo
Fs : Bluetooth Blackberry Remote Stereo Gateway
Brand new used only once to see if it worked. Comes with everything from factory including manuals and even the plastic still on it. just no box, threw it out.
Reason for selling : Doesnt work with my prada , though it worked with my friends $50 telus phone...
Play music stored on your BlackBerry®(or similar bluetooth equipped phone) smartphone wirelessly through your home stereo system with the BlackBerry Remote Stereo Gateway.
To wirelessly transmit your music, simply connect the BlackBerry®Gateway using the accompanying 3.5mm stereo cable or RCA auxiliary cable to your stereo system, turn on the gateway, pair your smartphone, and that's it!
The BlackBerry Remote Stereo Gateway is also compatible with other Bluetooth enabled mobile devices so you can stream your music from your PC, laptop, or any other A2DP-compatible mobile phone - in addition to a BlackBerry smartphone.
This easy to use accessory is great for those looking to enjoy their music the way it is supposed to be heard.
Wirelessly control music on your home stereo
Includes 3.5mm stereo cable and RCA auxiliary cable.
One of the smallest music gateway's available
Easy to use, one touch pairing
Includes BlackBerry Folding Blade Charger
http://us.shopblackberry.com/e....aspx
retails for $89.99usd
looking for $70cdn ( this is essentially brand new sans the box )
Located Downtown, can deliver a reasonable distance.
aristo is offline   Reply With Quote
