Old 04-01-2009, 12:22 AM   #1
Ceeker
e30 radio code rejection
Could anyone explain to me why my car won't take the radio code?
I entered the correct code and it let me finish but it beeped after the last number. Tried it 3 times still no luck.
Disconnected the battery and tried again; no go.
Then left the car ignition in access. mode for 1 hour and code is still rejected.
in case you're wondering, sometimes this is what in necessary for the radio to take the code.
Does anyone else have any other ideas on this matter?
thank you.
Old 04-01-2009, 12:59 AM   #2
SamE30e
SamE30e's Avatar
Wrong code?
85 325 - Turbo M52B28.
Old 04-01-2009, 07:17 AM   #3
Ceeker
no no, it's the correct one. I called my buddy at the dealership to check it for me.
Old 04-02-2009, 12:22 AM   #4
THE GURSH
Did you try with the car running for an hour?
THE GURSH is offline   Reply With Quote
Old 04-02-2009, 08:06 AM   #5
Ceeker
Car running? I never thought about that; I could try it. But from my understanding the ignition should only be in accessory- this is what I was told by a bmw tech and parts personel.
Old 04-02-2009, 12:56 PM   #6
Running or not wouldn't make any difference to the radio. If you are pressing the numbers in the correct order and it doesn't work I'd say something's farked in the radio or you have the wrong code. Even if your buddy says its right. Obviously something is wrong or it would work.
Are any of the buttons sticky or anything, that might be causing confusion to the deck?
Old 04-02-2009, 02:33 PM   #7
Ceeker
nope and nope...so I suspect the deck is pooched....
