Old 03-31-2009, 11:11 AM   #16
lvan
lvan's Avatar
^ your alternator could be going. That is if you got a decent battery. Do your headlights go brighter at night when you give it gas?
Old 03-31-2009, 11:14 AM   #17
eta Epsilon
I bought the battery last night!!!! It's brand new!!|!
03' Ford Focus ZX5, DD
02' Suzuki Katana, Summer fun
86' 325E, All year around fun (it's working, for now)
08' Kia Rondo, Girlfriend's car
eta Epsilon is offline   Reply With Quote
Old 03-31-2009, 11:18 AM   #18
Battery light: alternator. Your battery was new and freshly charged, so it didn't show up until the battery started to die, ie, after a period of running the car. You need to test the car's voltage with a meter, but I bet that's why your last battery was weak. Or, a dead battery or a shorted one can ruin the alternator since it is trying to charge something that is shorted or draining badly.
There should be a small rubber tube that goes out the drain flap towards the ground. This should be connected to the vent line on the battery.
Old 03-31-2009, 08:14 PM   #19
5thseries
biggerthen3
Buy my taurus, the stupid thing isnt gone yet
5thseries is offline   Reply With Quote
Old 04-01-2009, 06:47 AM   #20
eta Epsilon
no thaks, I have enough problems
Old 04-01-2009, 10:37 AM   #21
Update? What is happening?
Old 04-01-2009, 11:01 AM   #22
eta Epsilon
It's now at the garage. They will check it out this morning.
I drove it last night from the gas station to the garage. There was some strange noises coming from under the hood and the rmp was not stable.
I'll keep you guys updated
Old 04-01-2009, 11:46 AM   #23
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
sounds like you have a faulty alternator and/or your wiring is keeping something on to drain your battery...
punnzzells is offline   Reply With Quote
Old 04-01-2009, 01:03 PM   #24
Alternator is easy to find. Leaking head gasket: not so much.
Old 04-01-2009, 01:13 PM   #25
eta Epsilon
hey guy, just in case I need one, anybody as a alternator for a 86 325e?
Old 04-01-2009, 01:36 PM   #26
supernaught
supernaught's Avatar
ive got one for an M20, not sure if they're compatible, never played with an e
Old 04-01-2009, 01:37 PM   #27
eta Epsilon
It looks like i was a bit lucky in my bad luck.
The strap that gives power to the water pump and to the alternator broke down.
So no more water to the engine, and no more power to the battery...
The pressure build-up in the radiator causes the coolant to be ejected from the system, so that explain the steam.
I was told the engine did not suffer from it...
The strap will be replaced this afternoon. They will let the engine run for about 45 minutes just to be sure everything is fine.
If it's only that and that there is no permanent damages to the car, I will pray the lord tonight...
I'll keep you guys updated.
Old 04-01-2009, 01:39 PM   #28
supernaught
well that is pretty lucky, shame you didnt notice the belt failure before.
Hope all goes well
Old 04-01-2009, 01:46 PM   #29
Dado 540
Dado 540's Avatar
While you at it clean the battery clamps/connectors. If there is any corrosion on them it could cause problems.
And look at the brighter side, you now know that batterie is actually spelled battery, just kidding i had to.
E39 540i Sport
Old 04-01-2009, 01:56 PM   #30
eta Epsilon
F*** you!
Kidding, I can take a good joke when I deserve it.
Hey, I'm learning here!
