Old 03-24-2009, 08:52 AM   #1
clementine
speedo lights dont work properly!
just wondering if anyone knows why my speedo lights dont work when they ar esupposed to? For example when the switch is on for the high beam and fogs the speedo lights dont work. thanks for your help in advance.
clementine is offline   Reply With Quote
Old 03-24-2009, 09:00 AM   #2
stan man
Try:
turn the lights on with the knob thing, wigle it clockwise and counterclockwise, maybe the dimmer is set too dim.
smack the dashboard above the speedometer a few times.
if none of the above works, you need to replace two bulbs inside the cluster.
Should work after
________________
stan man is offline   Reply With Quote
Old 03-24-2009, 09:10 AM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
hopefuly your dimmer is set too dim.
if you end up relpalcing the bulbs and it still doesnt work, i would check your wires and connections.
flickr
