Old 03-21-2009, 11:33 PM   #1
Spawn44
what pads should I use
So after alot of searching I have decided to dive into the power detailing by purchasing a PC 7424 (most likely from eshine)
Now because my car is a titanium silver and hides the very light amt of swirl marks on it, I was going to use the klasse AIO as my polish( I know it doesnt have strong polish properties, but like I said I have minor swirl marks)I will apply it with the PC (since some forums have said with machine and right pad it will fix minor swirl marks) and will top wit Klasse SG like I normally do by hand (two coats)
So has anyone had experience with using AIO with a maching and if yes which pad did you find made the best result.
plus is there a good light polish i can use before the AIO .
And I normally top the sg with p21s but was thinking of just toping it weekly or biweekly with SG diluted to make a QD(not sure on the ratio of water but have read 4 to 1 or 5 to 1)
but if i do go back to the p21s should i buff it off with the pc and a mf bonnet, will this give me more shine/gloss
Thanks in advance for any suggestions
Spawn44 is offline   Reply With Quote
Old 03-22-2009, 12:58 AM   #2
ImolaZHP
ImolaZHP's Avatar
Klasse AIO doesnt do much for swirls. If you just have light swirls, I'd go with ssr1 or 2, menzerna final polish, megs 83, etc. something with light abrasives.
you might be able to get away with doing a couple passes on just a white pad, but if that doesnt work then try orange then white
i think 5:1 is the correct dilution for SG to make a QD
www.autopia.org
search here to get more (and better) answers for your detailing questions
ImolaZHP is offline   Reply With Quote
Old 03-22-2009, 03:21 AM   #3
Gamite
Gamite's Avatar
^^ what he said. Klass only has a masking agent, you don't need any kind of special pad for them. With abrasive polishes, you always want to start with the lightest pad and work your way up.
www.gamite.net
Old 03-22-2009, 04:42 AM   #4
Dado 540
Dado 540's Avatar
All the abbreviations are making my head spin. CG SQ p201.32 HG kl 5-3HPJ
E39 540i Sport
Old 03-22-2009, 01:47 PM   #5
ImolaZHP
ImolaZHP's Avatar
haha if your head wasn't spinning enough already...
Enjoy!
http://www.autopia.org/forum/car-det...1-26-07-a.html
Old 03-22-2009, 02:21 PM   #6
Spawn44
thanks for the tips guys
Old 03-22-2009, 02:23 PM   #7
Dado 540
Dado 540's Avatar
Wow that's a long list. Definitely a head spinner
E39 540i Sport
