Old 02-25-2009, 01:57 AM   #1
matty.dc
matty.dc's Avatar
E30 turbo
What parts would i need to turbo my e30 (aside from low comp pistons, head studs) and how much work would this involve?
2012 Hyundai Veloster Tech- Daily Driver
Old 02-25-2009, 11:46 AM   #2
SamE30e
SamE30e's Avatar
I head, ETA bottom end. Then you don't need low comp pistons.
91 318is - M50NV (gone)
85 - 325
02 325i Sedan
Old 02-25-2009, 02:46 PM   #3
You don't need either of those. Turbo'ing either an "eta" or an "i" motor has been done a thousand times. You need at a minimum a manifold, turbo, downpipe, exhaust work, fuel management, a wideband, oil feed lines and oil drain. Also plan on an intercooler, plumbing lines, air intake filter and a lot of learning and manual labour.
Or, just throw money at it and take it to a shop.
Optionally, there are lots of things to do. Low compression, o-ring the head or block, metric blue bolts, head studs, external wastegate, spark control, EGT monitoring, fuel and spark control via standalone, intercooling upgrades, clutch, traction improvement (tires), etc.
Old 02-25-2009, 10:08 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
I would stay away for metric blues. I never knew they're just a random fastener guys have used with some success, though ive seen the downside of using them (stripped block threads)
I'm pretty sure with a new stock HG, ARP studs and a GREAT tune you can boost up to 20psi no problems as long as the motor is somewhat in good mechanically good shape and you surround yourself with good turbo components (Standalone, properly sized turbo, exhaust, intercooler, clutch etc)
As for doing WORK, PM FuryriderX. He's done an entire turbo build in his driveway and im sure he could tell you what you would need to be able to do to get it done on your own.
Old 02-26-2009, 05:46 PM   #5
FuryriderX
cra.iX.y
FuryriderX's Avatar
w00t!
Old 03-18-2009, 11:03 AM   #6
"k"car man
"k"car man's Avatar
If you want to come by and see my cheapo turbo set up Let me know I'm in Burlington, the car isn't on the road yet, but I hope it will be before the summer.
And I did it in my driveway rain or shine
"k"car man is offline   Reply With Quote
