Old 04-10-2009, 11:44 PM   #16
supernaught
supernaught's Avatar
swapped AFM and same result. Also replaced dist cap and rotor.
Still the same high idle.
Could my timing be off?
still havent changed the tps or ecu
Old 04-11-2009, 11:33 AM   #17
1'M Seriesus
what are the exact symptoms of your engine,
has your check engine light or anything is it stumbling, lack of power? poor fuel economy? noise/vibration?
1'M Seriesus is offline   Reply With Quote
Old 04-12-2009, 09:06 PM   #18
supernaught
no check engine light. stumbles and vibrates only slightly at idle. lack of power <2000 rpm. Smooth and pulls hard above that. I haven't been driving it enough to note fuel eco.
List of things ive done:
Battery
Alternator
Plugs
Plug wires
ICV
AFM
Dist cap
Dist rotor
Coolant temp sensor(for cluster)
Throttle cable
Seafoamed(clean)
I think all hints point to timing.
Old 04-13-2009, 09:59 AM   #19
1'M Seriesus
i'm thinking either bad gasoline, dirty injectors or intake and vacuum leak?
