Old 03-06-2009, 05:30 PM   #1
coolshyguyhe
coolshyguyhe's Avatar
Send a message via MSN to coolshyguyhe
Question Where is the Factory amp located?
I am kinda new with my E46 whenever i play music i get some nasty noise from the rear and passenger side speakers... i think its something to do with the factory amp, its only does it if i try to turn it up... I am not sure where the amp is located in my 4 door 2000 323I? Could someone help me here? also would this be a fuse issue? And where can i get a replacement Amp if this one is toast? i am in oakville.
coolshyguyhe is offline   Reply With Quote
Old 03-07-2009, 09:31 PM   #2
BSL
BSL's Avatar
Likely a bad speaker, or poor connection.
The Amp is in the trunk, drivers side, behind the carpet stuff.
Try swapping the speakers side to side, before you replace the amplifier.
http://forum.e46fanatics.com/index.php
^^ this is a goldmine of e46 info
BSL is offline   Reply With Quote
Old 03-07-2009, 09:55 PM   #3
King Luis
The King.
King Luis's Avatar
what kind of noise are you getting?
amp is usually by the driver side shock tower.
2004 Silver Gray M3
Old 03-07-2009, 10:18 PM   #4
coolshyguyhe
I took the speaker covers off my car.. and noticed the speakers are rotted in the front and back... So i guess the plan is to replace them now.
Now as far as i understand the US version has 6 1/2 inch speakers all around? is this true?
Where could i get a good set of speakers for this ? nothing to expensive as i am still a student
Old 03-07-2009, 10:38 PM   #5
BSL
BSL's Avatar
I think what is recommended is a component set, if you are planning on keeping the stock amp. Lots of stuff on ebay and kijiji.
There is a company that specializes in building a kickass upgrade using upgrade speakers and keeping the other components stock. Do a seach for Stage 1...
My car stereo sounds like ass, and its all working right Im putting in all aftermarket stuff for 1/2 the price of a good set of component set of speakers.
Its going to be a lot of work, but all the info is out there if you search.
Old 03-07-2009, 10:58 PM   #6
coolshyguyhe
i can just buy 6 1/2 speakers from anywhere? Future shop, best buy ..ect? Or do i need some kinda special mounts?
Old 03-15-2009, 12:00 AM   #7
Randy
Randy's Avatar
you can buy my 6.5s from me! They are stock from my US-market E46. If u need one, two or all 4 - let me know.
Randy is offline   Reply With Quote
