Old 03-09-2009, 11:09 PM   #1
Redster
Stuck In The 6th Gear
Redster's Avatar
300W Light?
I need one, possibly two, 300W light sources to be powered (attached to) my navigator. Will regular power inverter be able to do this and will the vehicle be able to power one, or two, of these reflectors?
"You wanna make moves on the streets? Do not have any attachments, do not have anything in your life you are not willing to walk out on in 30 seconds flat if you spot the heat around the corner."
Redster is offline   Reply With Quote
Old 03-09-2009, 11:14 PM   #2
JUICY J CAN'T
propr'one's Avatar
Your alternator might not take the beating for long, but you could probably get them to start (Assuming you're running HID's). You would want to use a 1000 watt power inverter for each. (i'd strongly recommend only having one).
hid headlights
Old 03-10-2009, 12:17 AM   #3
Redster
Redster's Avatar
Any idea what's needed/required to successfully run two of them?
Old 03-10-2009, 12:53 AM   #4
JUICY J CAN'T
propr'one's Avatar
HID's need a lot of power to start, but not a lot to keep them going.
I'd make sure i have a real good battery, minimum 140 amp alternator, and get
2 X capacitor (same measurement of fahrads per watt as a amp, afaik .5 fahard per 200w)
2 X 1000w inverter
and big gauge wiring between the battery, cap and inverter.
If the car is leased, dont get the alternator (just wait for stock one to go. With the caps, it might last longer)
I can see if i can get you a DC/DC 300w HID kit a kit that would run on the car's stock 12V system, but i'm 99% sure there's nothing with that kind of wattage available.
hid headlights
Old 03-10-2009, 10:18 AM   #5
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
300W @ 13.9V @ 80% inverter efficiency = 27 amp draw per light. You're looking at roughly 60 amp draw, make sure your wiring is up to snuff, and you will have to wire it directly to battery (obviously) as cig lighter is rated at 10 amp max (most cars are 5 amp).
Old 03-10-2009, 03:25 PM   #6
JUICY J CAN'T
propr'one's Avatar
^^just wanted to point out that the 60 amp draw will be from the inverters and ballasts themselves. If your vehicle has a 80amp alternator, you'll only have 20 amps to run everything else (heated seats, rear defogger, fuel pump, amp, etc can take up a lot of power)
hid headlights
Old 03-10-2009, 03:40 PM   #7
magnus
magnus's Avatar
Out of curiosity but why do you need such a powerfull light?
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 03-10-2009, 04:12 PM   #8
Axxe
Axxe's Avatar
There are two types of people in this world. Those with loaded guns and those that dig. Now dig.
Old 03-10-2009, 10:13 PM   #9
Red_Rocket
Red_Rocket's Avatar
Slightly off topic but could i do this to my e30? how many amps do the e30 alternators put out? (mostly just curious how many amps my alternator puts out)
Red_Rocket is offline   Reply With Quote
