Old 03-07-2009, 08:15 PM   #1
Addict
HELP! Trouble with subs/amp on stock HU with HK
Okay so I had my amp and subs wired to my stock HK system and here are my problems:
-bass is amazing when IDLING but begins to get muddy and terrible as soon as I go above 40km/hr, exactly like what happens with my HK 6x9s - they used to distort once the car went faster than 40km/hr. I guess this has to do with the vehicle's speed sensitive volume control adjusting the signal on the fly.
-loud humming sound at idle
My setup:
-LOC from the main stock amp -> RCA to aftermarket amp
-remote turn on from the HK mini-amp (stupid installer)
Why is the signal changing as I drive, just like with the stock HK 6x9s? Is this solely due to the remote turn on trigger from the HK amp, and can be fixed by tapping into the MAIN amp for the trigger?
What is causing the loud humming at idle?
Imola Red / Imola Red ///M5
E60 SSK, Dice iPod, Illuminated ZHP knob, GT Custom Exhaust, BCR Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
Old 03-08-2009, 12:02 PM   #2
matty.dc
matty.dc's Avatar
usually a loud humming at idle in my experience has been a power wire running near or around the RCA's. As to the speed sensitive volume can you turn it off? I know in GM's you can and that may eliminate the distorting through different speeds.
2012 Hyundai Veloster Tech- Daily Driver
Old 03-08-2009, 01:34 PM   #3
Addict
You can't turn it off in the E46. I think the HK amp might have some sort of active cross-over system where it's adjusting the sound on the fly. Would this cause the problems I am describing above?
Past:
Old 03-08-2009, 01:48 PM   #4
spoony_prelude
Eurowerke
spoony_prelude's Avatar
buy a new car
Old 03-09-2009, 03:46 AM   #5
Randy
Randy's Avatar
How about when you rev? is there a power-drop (in bass) when you rev yuor engine? do lights dim when the bass hits hardest? - you may need a capacitor
Randy is offline   Reply With Quote
Old 03-09-2009, 10:34 AM   #6
Addict
None of this happens. I moved the amp last night as I was trying to check the wiring, and somehow that did the trick. I think the wires were all squished up and coming into contact in the amps previous location, everything seems okay now (at idle anyways). I'll see how it is after driving today - hopefully I'm good to go.
Past:
Old 03-09-2009, 11:33 AM   #7
matty.dc
matty.dc's Avatar
it was probably just power wires running near/beside the rca's
Old 03-09-2009, 11:58 AM   #8
ie, picking up feedback from another wire/source.
What brand of amp? Usually cheaper amp pickup feedback easier than others.
Dare I squeeze
Old 03-09-2009, 12:04 PM   #9
Addict
It's an incredibly shitty amp.
Past:
Old 03-09-2009, 12:19 PM   #10
matty.dc
matty.dc's Avatar
ha ha oh well it does the trick doesnt it?
