Old 03-06-2009, 10:50 AM   #1
noid
noid's Avatar
Stripped threading need new hole tapped.
The threads that my atv's transmission fluid release bolt screws into is stripped and needs to be retapped (one size up from 17mm).
Anyone know where i could get this done around the burlington/oakville/hamilton/mississauga area?
Old 03-06-2009, 11:33 AM   #2
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
if its just a casing that bolts on the side of the transmission id take it off and re tap it myself if thats not the case it would be a little bit harder to tap and not get shavings in your tranny.
90 sedan hx50 holset
86coupe30 is offline   Reply With Quote
Old 03-06-2009, 11:47 AM   #3
Trouble65
Do it your self it's cheap and works. WHat you need is HeliCoil and is available at most automotive stores.
Trouble65 is offline   Reply With Quote
Old 03-06-2009, 11:56 AM   #4
86coupe30
1990 325is
86coupe30's Avatar
^^I was going to say heli coil aswell but then i thought back and i have never seen that done on a drain plug.. might work..
Old 03-06-2009, 12:22 PM   #5
Mr seville
Mr seville's Avatar
retap it urself then put a magnetic drain plug incase there were any stray shavings it'll pic it up, along with any other metallic junk in ur oil pan.
side note: anyone handy with ATV's mechanics around here?
Mr seville is offline   Reply With Quote
Old 03-06-2009, 12:23 PM   #6
86coupe30
1990 325is
86coupe30's Avatar
well since the part of the tranny is pretty much garunteed to be cast aluminum that is non megnetic that might not work.. but for other shavings yea thats sweet.
Old 03-06-2009, 12:39 PM   #7
Mr seville
Mr seville's Avatar
shot down
Old 03-06-2009, 09:45 PM   #8
Trekz
why not just get the dain plug repair plug that doesnt need any thread
Old 03-07-2009, 12:52 AM   #9
noid
noid's Avatar
How does it work? and where can i get one?
Old 03-07-2009, 01:50 AM   #10
Trekz
partsource sells them i think. it look somthing like this |---------0
the | goes - then into the oil pan and its goes back like this | in the oil pan lol so it doesnt come out and the 0 part is like a drainplug it got a gasket on it and it just tightens up.
Edit: found a picture
http://www.cgenterprises.com/1030.h1.gif
Old 03-08-2009, 10:13 AM   #11
TNation
wow perfect advice by quite a few people here
i didn't even have to say anything!
