Old 03-04-2009, 10:16 AM   #1
eta Epsilon
Coolant light is on
Hi guys,
The check light for coolant is on.
Is there a post or a website that describes what steps should be taken in order to find the problem?
thanks!
03' Ford Focus ZX5, DD
02' Suzuki Katana, Summer fun
86' 325E, All year around fun (it's working, for now)
08' Kia Rondo, Girlfriend's car
eta Epsilon is offline   Reply With Quote
Old 03-04-2009, 11:44 AM   #2
Check your coolant level would be a GREAT first step.
Old 03-04-2009, 03:41 PM   #3
supernaught
supernaught's Avatar
next, put a piece of tape over the light
or buy a new sensor(fits in the coolant resevoir).
Old 03-04-2009, 03:44 PM   #4
You can also remove the sensor from the tank, clean it and reinstall. If you're handy, check the two pins with a multimeter and see if it switches when the float moves. If it doesn't , replace it. $35 part.
Old 03-04-2009, 05:00 PM   #5
supernaught
^ theres your answer
Old 03-04-2009, 05:19 PM   #6
eta Epsilon
OK, so the light is only connected to the sensor in the tank, not to anything else?
Old 03-04-2009, 05:23 PM   #7
That's right.
Old 03-04-2009, 05:39 PM   #8
eta Epsilon
Ok, that is good to know...
Old 03-07-2009, 11:08 AM   #9
eta Epsilon
Ok, coolant level is a bit low, I will buy some later today.
I would like to clean the sensor also. Do I only have to turn the black plastic piece to remove it?
What should I use to clean it? Water? Alcool?
thanks
Old 03-07-2009, 11:31 AM   #10
BabyHerc
Lulz
BabyHerc is offline   Reply With Quote
Old 03-08-2009, 04:05 PM   #11
eta Epsilon
OK,
I've added some coolant and I've cleaned the sensor.
The light is off, so I guess I solved the problem.
Thanks to all for the advice.
