Old 03-03-2009, 06:16 PM   #1
Guilherme
Top Gear Member
Check front fog lamps & tail lamps
Hey guys,
I'm getting these two messages on my instrument cluster display:
* Check front fog lamps
* Check tail lamps
I checked and they are all working What could this possibly be? Broken sensors?
98' 540i
Guilherme is offline   Reply With Quote
Old 03-03-2009, 10:49 PM   #2
5thseries
biggerthen3
Check out your fuse.. or the just disconnect, then reconnect your battery .. should be cleared.. <- that resets the computer
5thseries is offline   Reply With Quote
Old 03-04-2009, 02:54 PM   #3
Dado 540
Dado 540's Avatar
Maybe you got some moisture that got in there. But like mentioned above try reseting.
E39 540i Sport
Old 03-05-2009, 03:08 AM   #4
Guilherme
Top Gear Member
Thanks guys, I'll try that!
Old 03-05-2009, 04:40 PM   #5
Dado 540
Dado 540's Avatar
Did you do it? did it work?
E39 540i Sport
Old 03-07-2009, 05:06 PM   #6
Guilherme
Top Gear Member
Not yet Dado, I'll try it this weekend...
Old 03-28-2009, 08:24 AM   #7
Fernando
Fernando's Avatar
If your getting a check bulb light and the lights are all o.k. then the system is reading a different resistance from the bulb.... possibly aftermarket bulb, which the LCM (light control module) should reset by itself over 3-4 starts of the car....
"I told you a million times, I hate it when you exaggerate !"
Fernando is offline   Reply With Quote
