Old 02-16-2009, 11:46 AM   #1
Ryan Ahn
number plate light is in trouble...
One of my rear number plate light is in trouble.
I tried to change that bulb, but it still doesn't work.
I think the electronic wire is damaged....
If I go the dealership to fix it, they will charge it?
Otherwise, usually how much it will be charged in general shop?
thank u guys.
Have a good family day.
Ryan Ahn is offline   Reply With Quote
Old 02-16-2009, 02:57 PM   #2
topaz330ci
Bang Boom
topaz330ci's Avatar
Hahaha,
Squeeze the two little metal connectors together a little tighter, put in the new bulb and make sure its nice and secure without any play.
that should do the trick... if not, then you have a little electrical problem.
topaz330ci is offline   Reply With Quote
Old 02-17-2009, 06:24 PM   #3
Junaid
what car do you have?
Junaid is offline   Reply With Quote
Old 02-17-2009, 10:04 PM   #4
Ryan Ahn
04 E46 325i Sedan
Old 02-18-2009, 06:37 PM   #5
Junaid
when you pull open your trunk, there will be a rubber hose on the right side, slide it back and see if any wires are broken.
