Old 02-15-2009, 12:43 PM   #1
dodoamore
To Rotate or Not to Rotate that is the ?
Fellas, (looking to do some wrench'n this long weekend)
I know there are mixed views depending on set up/model/tires/ect. However looking to get your recommendation on my current set up: 99 E39 540i, same size directional tires, non staggered set-up
Thinking of the following Tire Rotation, for the above set up: Front to Rear (rear driver to front driver & rear passenger to front passenger..vice versa, respectively)...
Ps...did I blow a fuse or something: I have to pull my driver door handle twice to exit (I understand the concept of once to unlock, the second to open the door) but shouldn't at least the front unlock automatically once ignition is off or is there a way to program the system to unlock front doors once ignition is turned off?
Thanks in advance
dodoamore is offline   Reply With Quote
Old 02-15-2009, 02:03 PM   #2
slemmer
Driving in the fast lane
slemmer's Avatar
I usually do a same side rotation for 4 since the spare is usually a different type
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 02-15-2009, 03:17 PM   #3
Dado 540
Dado 540's Avatar
I know you can have the settings changed so that the door locks atomatically once you start driving (20km/h+), or just have them stay unlocked untill you press the buttom in the center console. As for the unlocking with ignition off, i have never heard of that programming
E39 540i Sport
Old 02-15-2009, 04:57 PM   #4
richie_s999
you can only rotate dirrectional tire front to back, if you change sides the tread will be wrong.
Old 02-16-2009, 03:29 AM   #5
Qube
Mine locks at 20 and unlocks with ignition off. I have the eLight module though Must be possible.
Old 02-17-2009, 06:08 PM   #6
dodoamore
Thanks for your input gents., weekend rotation revealed a rear passenger broken spring., time for summer mod., .,
