Originally Posted by nickdaytona
Yup Roaster , it's definitely a sold car , I'm just hoping it's solid ! ;-)
Some areas to check for rust
-lift the carpet on the driver's side and look in the pedal area
-lift the carpet on the passenger side and look at the floor
-bottoms of the doors
-spare tire well (very typical)
-gas tank - remove and clean and maybe POR15
-behind heater if there is evidence of leaking
-frame rails (especially near the front where people have jacked on them - use a board or something instead of jacking right on them)
-rear strut towers, check inside and outside
-around windshields if the seals have gone bad
-the rear subframe/body connection - rubber bushing that bolts up through the body and ends up under the rear seat - if you are doing a complete resto break down the rear subframe and replace the bushings
-front quarters, look inside with a flashlight,especially towards the back where there is a prefect spot for crap to sit
-inside the "cave" where the fuse box sits
-behind the firewall insulation (if you pull the motor)
-drain tubes on sunroof cars
-anywhere the master cylinder has leaked on
-inside front of hood
Judging by the amount of sludge in your engine bay, the bottom of the car may have been "preserved" by moil (= mud + oil).
I ground all the crap off the bottom of my car, and POR 15'd the whole thing. A messy, thankless job, but a lot of piece of mind.
I have some spares and lots of advice, some of it actually useful, if you guys need anything
Kris
