Old 02-07-2009, 09:05 AM   #1
roger
Question how would i remove the bk bumper ?
hi i was hopein you guys would be able to tell me how to remove my back bumper i have backed into something and have knocked it off at one side was hopeing its a easy job to take off and just side back in to place ...
cheers
roger is offline   Reply With Quote
Old 02-08-2009, 07:02 AM   #2
328is
tire don't like me
328is's Avatar
i't s a very easy job. You have 2 8mm bolts each side inside the wheel well, remove the lower part in the back (2 clips) and then it's 2 TORKS (don't remember the size) bolts that you will have to remove and pull the bumper out.
race car souldn't be restricted to race track !
328is is offline   Reply With Quote
Old 02-08-2009, 09:12 AM   #3
roger
There are no bolts for the rear bumpers.. just a bunch of plastic studs behind the moldings that i had to hammer the pins right thu b4 pulling the rest out and a few small screws on the bottom and in the wheel well. You'll also need to reach in on the left and right side and try to slide the whole bumper outward away from the car.
well i got it off and tryed to get it back on but iv broke the clip that holds it on on the driver side so il be tryin agane once i gt the right part
thank for the help guys
Old 02-08-2009, 09:18 AM   #4
328is
tire don't like me
328is's Avatar
you are not suposed to remove the bumper from the reiforcement. You're suposed to remove everything together in one pieces.
The 2 TORKS bolt are under the bumper facing strait up. One is close to the exhaust and the other is the other side at the same place.
