Old 02-02-2009, 08:59 PM   #1
Another BM
Trouble hooking up Rockford amp to H/K amp in trunk
So i tried to set up my system today and ran into a problem.
I connected a transmitter into those speakers in the trunk that have the H/K (harman/kardon) cover. The one that sits at the top of the trunk, right in the center.
I ran the rca's to the amp and connected everything. Sub didn't work.
I then noticed no sound comes from those 2 speakers.
N e idea why those speakers aren't working..
while installing the transmitter no other wires got cut or disconnected.
the speakers were balanced
the H/K button inside the car is turned on.
i dont know if those speakers ever worked.
Is there a better way to hook up an amp and sub into the factory setup.
Another BM is offline   Reply With Quote
Old 02-02-2009, 11:26 PM   #2
Junaid
i was thinking of this the other day... i'm sorry i am not much of a help but i guess you could check the fuse?
but anyways after you figured out could you please post how you did it, i want to connect it to my factory stuff as well.
Junaid is offline   Reply With Quote
Old 02-03-2009, 09:15 AM   #3
StikiGreenZ
StikiGreenZ's Avatar
You should be getting your sound lead from the stock amp in the trunk, not off the speakers on the rear decklid.
BMW 645i - Black on Red
Old 02-03-2009, 10:39 AM   #4
Another BM
where is the stock amp located
Old 02-03-2009, 01:55 PM   #5
StikiGreenZ
Remove the carpet on the left side of your trunk, its basically on the left side where your gas cap is on the right side.
I foudn a wiring diagram online a long time ago, im sure its still up somewhere. You'll need a little adapter (forget the technical term for it) to convert the signal into something your amp can use.
Old 02-04-2009, 01:35 PM   #6
Another BM
did u post the diagram on max??
Old 02-04-2009, 03:23 PM   #7
I fund this diagram on Fanatics a while back:
Hope this helps.
Old 02-06-2009, 12:53 AM   #8
g_teg
hey sorry to break into the thread. But since your putting in a new amplifier in your car can i possible bug you for a part.
i just bought a car and the plug going from the sub amp ( mini amp ) to the 6x9 is missing. i was wondering if i can get that from you.
please PM me.
g_teg is offline   Reply With Quote
Old 02-07-2009, 12:44 PM   #9
Another BM
ayyyy.. i got it working.
sounds pretty sweet now.
g_teg.. sorry man, i like to keep all stock parts of my car for when i go to resell it.
Old 02-07-2009, 08:09 PM   #10
StikiGreenZ
I dont like how that diagram tells u to splice into the 6x9 input wires. It's better to splice into the amplifier's input signal from the deck, that's how i did it. I can't seem to find the diagram online though, sorry.
