Old 01-16-2009, 11:03 AM   #1
Michel
Michel's Avatar
Calling all M54 Owner's RE: Crankcase/Hydrolock
I know we've talked about this issue a lot here, but I would like to know if and who's experiencing problems with sludge build up and noise from their crankcase/oil seperator this year?
Does anyone have any other recommendations other than driving the car hard after warm-up? We've been experiencing this with my brothers car, and even after a full day of hard driving, the noise comes back today, sludge is apparent also(oil change done 2 weeks ago and replaced with insulated crankcase + lines last year). Is this problem with ALL M54's or a select and what are the odds of having the engine overflood? Also does a CAI induce this?
Thanks!
-Michel
Old 01-16-2009, 03:52 PM   #2
ImolaZHP
ImolaZHP's Avatar
i've just been driving for longer than i usually would. also long trips help. you want to get the oil at operating temps for long periods at a time. then you shouldnt have any problems.
you should only have issues if your taking repeated short trips.
Old 01-16-2009, 07:38 PM   #3
spoony_prelude
Eurowerke
spoony_prelude's Avatar
has this ever been an issue with s52's?
Old 01-16-2009, 08:12 PM   #4
Addict
No problems here in my 330 nor with my father's 330. He drives his car barely even 5 kms to work and the engine doesn't even have time to get fully warmed up - yet he hasn't experienced in problems in the 3 yrs he's owned it.
Dunno what's up with your brother's car, even though you had the crankcase taken care of last year. Try posting on Fanatics for more info (even though that shithole is more of a show and shine forum...).
Imola Red / Imola Red ///M5
E60 SSK, Dice iPod, Illuminated ZHP knob, GT Custom Exhaust, BCR Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
Old 01-16-2009, 11:24 PM   #5
Michel
Michel's Avatar
^See that's what I was thinking. Not all these engines have this problem and I wanna figure out why. I'm thinking it could be the CAI. Anuk did you put your intake back on or are you still using the stock one?
Old 01-16-2009, 11:36 PM   #6
Addict
I still have my Gruppe M thingy on there. Where are you seeing the sludge build up?
Past:
Old 01-17-2009, 12:08 AM   #7
Michel
Michel's Avatar
On the oil filler cap and on the dipstick... I had the car again today and after a lot of hard driving I opened the oil filler cap and it was dripping water and the sludge was bubbling! So I know it's evaporating... We also do drive long distances at least 3-4 times a week, but the condensation keeps coming back! I don't know if I'm being too pre-cautious or anal, but I would think most owner's would/should also notice this.
Old 01-17-2009, 01:03 AM   #8
Euro_E30
Euro_E30's Avatar
Seen this problem millions of times and alot of 2.5L and 3L engines both in the 3's and x5's, just this week alone ive done quite a bit of crankcase vent system due to low climate temps. these engines develop alot of moisture on cold start ups and depend on the condition of your crankcase system, the moisture will be burned off while driving/idling. Best thing to do is drive the car as much as possible, and some people after a long drive over night leave thier oil cap off so that the moisture escapes the engine instead of staying in the motor and freezing the crankcase system. Hope this helps in any way
Euro_E30 is online now   Reply With Quote
Old 01-18-2009, 02:06 PM   #9
ImolaZHP
ImolaZHP's Avatar
never heard of this..seems logical enough though.
and michel, what does the pcv noise sound like?
Old 01-18-2009, 06:11 PM   #10
Michel
Michel's Avatar
^Theres 2 noises actually.. the one I usually hear is a whistle, kind of like the intake, but much louder and goes away after 3000rpm. The second noise I hear is usually around 2000rpm, which sounds a lot like when you apply the brakes when they're rusty and they squeal.
After my two days of distance driving, I havent had problems since yesterday and today... then again it's not as cold as it was last week.
Old 01-18-2009, 06:20 PM   #11
Addict
Is the whistling sound an actual whistle, or is it more of a whirring sound?
Past:
Old 01-18-2009, 08:21 PM   #12
Michel
Michel's Avatar
^Whirring! that's the word lol...
Old 01-18-2009, 08:41 PM   #13
Addict
Does this whirring speed up as you rev it until about 2K where it gets drowned out, or is it constant? I noticed my car has a very slight whirring when it'd idling and cold.
I'm not sure if that's the symptom of a bad PCV, but I had that same thing on my E36. It turned out to be a bad alternator pulley - thankfully, a cheap fix! Wonder if it's the same issue for us or if it is more serious...
Past:
Old 01-18-2009, 11:16 PM   #14
Michel
Michel's Avatar
no well for me this noise comes at certain RPM's (never above 3000rpm tho) and only for a brief moment. It doesn't speed up or anything. And it goes away completely when the car is warm. Mind you, this ONLY happens when its ~ -15 + outside.
Anuk, just check your oil cap for the yellow sludge. your issue might be pulley like your sayin.
Old 01-19-2009, 12:16 PM   #15
BmW1718
Send a message via MSN to BmW1718
change it u get that farting noise??
1987 325is Red Summer Car
1992 325I 4 door Winter beater )
BmW1718 is offline   Reply With Quote
