Old 01-15-2009, 09:47 AM   #1
david.toledo
david.toledo's Avatar
Send a message via MSN to david.toledo
i think i have a big problem
one of my wheels pulls harder than the other one because when i accelerate hard the car takes me to the left side and sometimes when i speed up or shift down i feel a "tick" noise from the rear.
anyone?
david.toledo is offline   Reply With Quote
Old 01-15-2009, 12:29 PM   #2
BmW1819
does your diff has LSD??
Old 01-15-2009, 12:58 PM   #3
hypno_nls1
hypno_nls1's Avatar
ya if you dont have LSD both of your back tires arent pulling the same
Fear Nothing. Risk Everything.
This is not your everyday, ordinary ****ing beamer!!
hypno_nls1 is offline   Reply With Quote
Old 01-15-2009, 11:45 PM   #4
Yes and no....
They dont pull the same because one might loose traction, but the car will NOT pull to one side in ANY case!
Old 01-15-2009, 11:49 PM   #5
Check for seized brakes on the left side...Most likely rear left...The noise you are getting could be parts of your ebrake falling appart, i had that happen to me before. You get chuncks in there that make noise AND lock up the wheel.
Old 01-19-2009, 07:13 PM   #6
GTA_G20
My rear left e brake is dragging causing my issue exactly as you described OP
GTA_G20 is offline   Reply With Quote
Old 01-19-2009, 07:48 PM   #7
e brake snagged
caliper seized
half shaft ****ed
uneven tire tread/PSI
or (other than seized caliiper most likely)
rear alignment out of whack.
Old 01-21-2009, 12:29 PM   #8
david.toledo
hmm i am honestly leaning towards the half shaft ****ed.. cause it makes a tick noise when i down shift and tha brakes and ebrake work fine.
Old 01-21-2009, 12:30 PM   #9
GTA_G20
mine ticks too im pretty sure its the ebrake bro
Old 01-21-2009, 12:32 PM   #10
david.toledo
but i hope its not i am going to go get it cheked today . thanks
