Old 01-14-2009, 12:29 AM   #16
BmW1819
how about
when people can't find your inner door release and night
when u can't find anything cause there is no lights inside
Old 01-14-2009, 12:41 AM   #17
slimjim
Almost Sideways
^^ rofl i have to add to that.
you know you own an e30 when u have a flashlight in your car because when ur checking the grade/rolling ur bud u cant see shit.
you know you have an e30 when ur rear defroster doesnt work
when you buy spinning hub caps for ur "burnout" tires
Old 01-14-2009, 01:06 AM   #18
El Gato Liso
El Gato Liso's Avatar
you know you drive an e30 when you have to explain to people that BMWs are more than jsut 3 letters...in reference to older bmws such as your e30
R.I.P. E30
Old 01-14-2009, 01:17 AM   #19
You know you drive an E30 when your rear window explodes when you use the defrost...
When someone is confused how to open the hood...
When the center console is broken from putting it in reverse...
When people tell you "Sure those Honda rims will fit! they are 4x100!" and you laugh at them...
When your winter beater is newer then your car...
When you know for sure you would buy another one, if you get the chance!!!
Old 01-14-2009, 02:08 AM   #20
Chris de la Cruz
sex, drifting & punk rock
when you jam your drink b/n the passenger seat/ centre consol b/c you have no cup holders
when you go through flex disks
when you have to unlock from the passenger side b/c your driver side lock is broken
when your check brake light is on when you start your car then goes away when pressing the brake
when your e brake is akward to reach when drifting.
when you secretly admire sportmax wheels.
www.CSCS.ca
Old 01-14-2009, 02:23 AM   #21
SamE30e
SamE30e's Avatar
When you're too cheap to buy brake pad sensors, so you just take the steering wheel off, and the cluster out to remove the indicator light.
When people goto open the back door on your coupe because there should be a door there.
When you need to push your window switches down and to the right to open or close your window.
When you need to open your trunk and push the latch out from the inside to close it again.
85 325 - Turbo M52B28.
Old 01-14-2009, 03:40 AM   #22
slimjim
Almost Sideways
you know u drive an e30 when ur obc looks like the Matrix.
Old 01-14-2009, 08:02 AM   #23
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
You know you drive an e30 when you do it this way instead of taking off the wheels and grounding out the sensor.
You know you drive an e30 when the thought of having to smell the bumper shock oil again makes you want to puke.
Stanceiseverything.com
Old 01-14-2009, 09:51 AM   #24
You know you drive an e30 when you go to roll down the window in any other car, and reach for the center console.
Old 01-14-2009, 09:52 AM   #25
stan man
Originally Posted by BMW BMXer View Post
You know (or knew in my case) you drive an e30 when your passenger asks if birds are in your dash when you turn the heat on.
^ this is so true
but I have those grasshoppers or crickets or whatever living in mine when the fan is on low. It's kind of nice - very relaxing
stan man is offline   Reply With Quote
Old 01-14-2009, 10:00 AM   #26
stan man
When you learn the words like OFFSET , LSD , and know of hand what tire size goes
with what wheel - then you know you are in an e30
Old 01-14-2009, 11:22 AM   #27
MiroE36
MiroE36's Avatar
You knwo you drive an e30 when you use the trunk for central locking because none of the other locks work
Old 01-14-2009, 11:33 AM   #28
dgmorr
...when your crotch is scorched and wet from holding that cup of Timmy's while you drive.
...when your lower back aches from adjusting the valves so often.
Old 01-14-2009, 01:13 PM   #29
BmW1718
Send a message via MSN to BmW1718
that's why i have twin cup holders in my car
1987 325is Red Summer Car
1992 325I 4 door Winter beater )
BmW1718 is offline   Reply With Quote
Old 01-14-2009, 01:14 PM   #30
Rezae32
They are all soooooo funny cuz they are all soooooo true!!!!
Rezae32 is offline   Reply With Quote
