Old 01-11-2009, 03:04 PM   #1
Qube
Crack in bumper...
Cracked front bumper near fender at the mount. About 2.5 inches long. Where to get it fixed in a day in the GTA? No painting needed.
Old 01-11-2009, 10:47 PM   #2
Qube
Screw it, I'll fix it myself Now how and what to fix it with...
Suggestions welcome!
Old 01-12-2009, 12:06 AM   #3
What the shit did you do?
Old 01-12-2009, 01:30 AM   #4
doogee
doogee's Avatar
I'm not quite seeing what happened or whats cracked by the pics.
But I'm sure Bondo makes something you can use like a fibreglass kit to patch it up from behind.
Dakar M3 Track Build Thread
Old 01-12-2009, 02:00 AM   #5
slimjim
Almost Sideways
what i would do.....take the bummper off, fiberglass it from underneath to have a smooth surface, and then bondo over the crack. u could also dremel a groove along the crack and then use bondo to fill in the groove...but still use the fiber glass. the groove is just so the bondo layer isnt so thin that it might just crack over time.
edit, better yet, fill the crack with fiber glass resin and sand that down instead of the bondo...much stronger.
Old 01-12-2009, 02:18 AM   #6
Firberglass or and most resins wont stick to plastic, and will crack very fast...Bondo is just a joke...No filler sticks well to plastic. I can tell you what works on it, but the smallest amount you can buy is over $100...Or i can do it for $75!
Old 01-12-2009, 07:57 AM   #7
Trouble65
Plastic weld. Your local auto body shop carries the product.
Old 01-12-2009, 09:43 PM   #8
team_ottawa
team_ottawa's Avatar
yea i was just gonna say u can get a plastic repair kit made of the product and a harder i know where u can get it in hamilton but not toronto
stance is everything
<img src=http://i735.photobucket.com/albums/ww359/team_ottawa/pic5.jpg border=0 alt= />
team_ottawa is offline   Reply With Quote
Old 01-12-2009, 10:42 PM   #9
5thseries
biggerthen3
Body filler.. sand that bitch and pant it. =)
5thseries is offline   Reply With Quote
Old 01-12-2009, 10:52 PM   #10
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
apparently there is stuff at napa that is plastic filler.. its like a 2 part epoxy you mix and it sets like body fill or epoxy.. you can sand it like regular plastic too apparently.. if i were you i would get a small driill bit and drill 2 tiny holes at the very ends of the cracks, all that does is if there is still flex in that part of the bumper it wont let the crack continue. and i mean really small like pencil dot small.. and then put masking tape behind the crack after bevelling it off and use said product.. i forget the name of the product though..
86coupe30 is offline   Reply With Quote
Old 01-13-2009, 12:12 AM   #11
Qube
The drill hole idea is neat. I'll try and use that. I picked up Plastic Weld at Canadian Tire. It rang up more than the tag at the register, so I got it for free
Old 01-13-2009, 07:04 AM   #12
Trouble65
Don't buy plastic weld from Canadian Tire. Go to your nearest autobody supply store. Trust me on this one.
Old 01-13-2009, 07:05 AM   #13
Trouble65
You are joking, right.
Body fill a crack, it wont last more then a few days if he is lucky.
