Old 01-08-2009, 10:20 PM   #1
rider-.
5x120 to 5x114.3 conversion??
does anyone have any info on converting to 114.3, do any companies make good quality adapters for completing this task?
Old 01-12-2009, 01:55 AM   #2
thinair
moderationistismingly
thinair's Avatar
The only adapters I've seen generally convert to larger bolt patterns, like 130mm (Porsche). What is 114.3mm, Subaru? Not to mention that any adapter (even a custom one) is about 20mm thick, which will means you'll need some high offset wheels.
Old 01-12-2009, 09:24 AM   #3
rider-.
yea i have no problem with 20mm thick.... 114.3 is ALOT of car manufacturers... that way i have alot cheaper wheel options as well as more wheel options
Old 01-12-2009, 11:58 AM   #4
DriveItSideways
240's, prelude/accord, subaru's, rx7's, supras, 300zx, ae86 are all 114. All the baller deep dish wheels come in 114, its the best hub size to have IMO.
I havent seen any pro hub adapters going from 120 to 114, pretty sure your gonna have to go custom.
Its probably cheaper to get a set in 120, otherwise you would need to roll/pull/ or go widebody to fit low offset 114. wheels plus a big adapter.
Old 01-13-2009, 01:34 AM   #5
rider-.
oh its for track car so either way fenders are being pulled or widebody maybe for jokes
Old 01-13-2009, 11:31 AM   #6
DriveItSideways
If its a track car then its in your best intrest NOT to have big adapters on. The studs break under hard cornering. Get a proper set of wheels that fit right.
Old 01-13-2009, 06:15 PM   #7
thinair
thinair's Avatar
this if it's a track car who cares what the wheels looks like Just get the lightest/strongest wheels you can afford.
Old 01-13-2009, 11:18 PM   #8
rider-.
that was the plan haha.. lightest strongest cheapest...
Old 01-14-2009, 02:45 AM   #9
thinair
thinair's Avatar
a hub adapter is never the strongest , plus they're going to be at the bare minimun $200 for a set (an H&R set would be like twice that, or more), not to mention that it's over a pound or a 20mm spacer.
Although, I found this place that will make custom spacers to whatever spec you like.
http://www.serpentautosport.com/HTML...20Spacers.html
Old 01-14-2009, 10:09 AM   #10
stan man
Just to add:
I think subaru is 5x100, not 5x114. Toyota and Lexus are 114
stan man is offline   Reply With Quote
