Old 01-08-2009, 04:55 PM   #1
-shockaz-
Trick paint...
Send a message via MSN to -shockaz-
1998 528i check engine light p0173
P0173 Fuel trim 2 on my 98 528i, searched around on the internet couldn't find any cases with just one code showing.
its the only code that show on the CEL, i tried to reset the code it came back after 10 mins of driving.
Engine runs fine, no hard starts rough idle. passed Ontario e-test with the light on.
anyone know anything about this? i've read a couple of articles about this but everyone had rough idle and vacum leaks, followed by other codes. Im just getting the one p0173 fuel trim bank 2
-shockaz- is offline   Reply With Quote
Old 01-08-2009, 05:06 PM   #2
-shockaz-
Trick paint...
i found some more info..
PO173 is fuel trim malfunction for bank 2 (cylinders 4 to 6).
Depending on the adaptation values (AKA, long term fuel trim or short term fuel trim)
Old 01-22-2009, 05:51 PM   #3
MaxVQ
You should get an OBD-2 scanner and see what the fuel trim is.
A large fuel trim (>10) indicates fuel is being added to fix a lean condition
A small fuel trim (<-10) indicates fuel is being removed to fix a rich condition.
MaxVQ is offline   Reply With Quote
Old 01-23-2009, 10:12 PM   #4
-shockaz-
Trick paint...
thanx i did.. it was going to 25.. one of the o2 sensors was showing .980 it was stuck at rich.. causing the car to trim to 25
Old 01-24-2009, 12:18 PM   #5
Max_VQ
Max_VQ's Avatar
Did you mean your fuel trim is -25?
If your O2 is reading rich, the fuel trim would be negative, as it is removing fuel from the baseline.
