Old 01-07-2009, 08:29 PM   #1
BMe30
all by chance...
BMe30's Avatar
quick question...
hey all,
do the e36 ball joint replacement fit in the e30 control arms? I think i read somewhere that they are the same. true?
thanks
Old 01-07-2009, 08:39 PM   #2
I think they fit. However, if they can or not, they are worse. Stick with the regular e30 ones.
Old 01-07-2009, 08:41 PM   #3
BMe30
all by chance...
BMe30's Avatar
gotcha
thanks
Old 01-07-2009, 08:51 PM   #4
BmW1718
Send a message via MSN to BmW1718
yea e30 ball joinits last long than e36 more than double
1987 325is Red Summer Car
1992 325I 4 door Winter beater )
BmW1718 is offline   Reply With Quote
Old 01-07-2009, 10:31 PM   #5
lvan
lvan's Avatar
So what is the difference between replacing the corntrol arms and ball joints? Do you get ball joints on your control arms monuted?
Old 01-07-2009, 10:38 PM   #6
BMe30
all by chance...
BMe30's Avatar
well when i first got my car they replaced one ball joint.. but not the control arm. so it is possible.. is it the same as just getting the entire unit new.. i don't know. anyone.. anyone.. bueller... bueller..
Old 01-07-2009, 10:44 PM   #7
New control arms come with new ball joints... But the ball joints are replaceable. So you can opt to replace the ball joints, but it will cost the extra labour to press them out/in... A choice whichever you see more cost effective/advantageous.
Old 01-07-2009, 10:46 PM   #8
lvan
lvan's Avatar
I was thinking the same. That clears up everything.
Old 01-08-2009, 09:11 AM   #9
m60e30
Send a message via MSN to m60e30
also i used to just press in ball joint after the fact, but get good ones, the cheap ones are done really fast
m60e30 is offline   Reply With Quote
Old 01-08-2009, 05:45 PM   #10
BMe30
all by chance...
BMe30's Avatar
where can i go to get these.. other than the dealer?
i also need to get wheel bearings all around.
Old 01-08-2009, 08:33 PM   #11
e30jones
My advice would be to not waste your time with pressing in new balljoints unless you are really strapped for cash, and are only replacing one joint. Someone told me that a few years ago, but I attempted to press in new balljoints in a set of old control arms anyway. It's a waste of time and money, unless you have your own press, or can get it done cheaply. I think I ended up paying $20 a piece for the balljoints x 2, and $20 to get 2 pressed in. So you're at $60 plus tax for one control arm. You can get good aftermarket control arms for like $80 each, none of the hassle of driving to machine shops, and you know that everything is in good working order.
Lots of online sites have e30 parts, I personally use autopartsway.ca, and/or carquest most of the time. I think I bought my control arms from willz.ca, but that was quite a while ago.
e30jones is offline   Reply With Quote
Old 01-08-2009, 08:53 PM   #12
BMe30
all by chance...
BMe30's Avatar
^^^^ thanks for the tip
and the sites
Old 01-08-2009, 10:58 PM   #13
Docherty
like said above. if you buy a control arm, your getting both balljoints. I would rather get a replacement outer that you press in for an e30. And where are you going to find "good aftermarket" control arms for $80?
Docherty is offline   Reply With Quote
Old 01-10-2009, 12:01 AM   #14
e30jones
I guess they're a bit more now, listed for $90 each on willz's site. They were Meyle control arms, which I'm pretty sure is a fairly reputable name; not Lemforder, but not as pricey either and they do the trick.
Do the outers wear out more frequently than the inners? If I'm going through the hassle of taking of the control arm, both balljoints are gonna be replaced. I suppose if you could press in a new outer with the arm still on the car, it would be worth it, but I don't know if that's possible. To each their own, just my opinion.
Old 01-10-2009, 09:38 AM   #15
BMe30
all by chance...
BMe30's Avatar
what is a good brand of ball joints to get?
keep in mind i plan on some autox and might it up a road course or two
