Old 01-07-2009, 08:07 PM   #16
PinkieMoscow
Jumped up G'd up.
I don't see what the problem is. Just put it on 4 and wear swimming trunks, come on man, seriously!
PinkieMoscow is offline   Reply With Quote
Old 01-07-2009, 08:57 PM   #17
1BADBMR
I smoke in my car and notice it creates a build-up of film on the windows. It fogs up like crazy in the colder months.
Now I clean my inside windows regularly and it helps a bit.
_____________________________________________
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
04 Honda Civic (Beater)
93 318i (SOLD)
1BADBMR is offline   Reply With Quote
Old 01-07-2009, 08:57 PM   #18
MiroE36
MiroE36's Avatar
lol your inhumane.
Old 01-07-2009, 09:00 PM   #19
MiroE36
MiroE36's Avatar
Originally Posted by 5thseries View Post
Sorry, didnt no that part of it lol, well, hot a cold air creates condensation, check for any kind of air leaks, from the doors, god forbid! a rust hole under the car.. some of those can lead to the fog build up..
holy shit... you know... the car is from quebec... and one of my friends was telling me that cars from quebec are notorious for rusted floors with holes... I'm going to check that out... OMG what if it is the case... What do I do then??
Old 01-07-2009, 09:19 PM   #20
5thseries
biggerthen3
Well, for the hole in the Floors, check your carpets, is it damp? you just did the winter driving which means snow and the dirt from the road got kicked up so that can be your answer.. but if not.. check your door seals.. look for any kinda of damage, see if they are on right,
for damages, have a look for the outstanding cracks and the holes.. that can be a contribute the the fog build up
5thseries is offline   Reply With Quote
Old 01-07-2009, 09:29 PM   #21
damameke
definitely air circulation is an issue
run the air-cond for a short period, it will get rid of moisture...give it a try
and get it check..
Old 01-07-2009, 09:37 PM   #22
5thseries
biggerthen3
and get it check..
This is extensive fog.. running the A/C will take for ever And also will only be a clear for a short period of time.
Old 01-07-2009, 10:57 PM   #23
damameke
no it wouldnt take forever.. . it helps.
give it a try and like i stated earlier have it check,
Old 01-07-2009, 11:37 PM   #24
MiroE36
MiroE36's Avatar
ok so i checked these are the results:
The door seals are fine, the window seals are good too, don't think it's from there... but man, I was comparing my two front mats... the driver side is soaked.. and the passenger side is dry... but I always drive my dad to and from work so there is about the same amount of snow on both mats... so I think this really might be the problem... ****shit! I'll have to get it lifted to take a look underneath.
If I do have a hole underneath... is there a home remedy for this?? I like working on my car and would be down for doing this if it's possible... please let me know?!!?
Old 01-08-2009, 07:31 PM   #25
5thseries
biggerthen3
Depending on how big the hole if, if you have a welding gun and illmatic skill, go ahead, but see what you are dealing with first before you tackle this job
Old 01-08-2009, 07:39 PM   #26
Dado 540
Dado 540's Avatar
They got this Magic Putty on infomercialls. Im sure some of you seen it. It can pull a truck, stop leaks, use it to hang things on the wall. Use that lol.
Old 01-08-2009, 08:38 PM   #27
MiroE36
MiroE36's Avatar
Lol I saw that thing... looks crazy lol. I'll have to deal with this during the spring... right now is not the best time...
Ummm do you guy's thing that it might rust more over the winter??? I did get the car oil sprayed at Krown early November. let me know please and thank you
Old 01-08-2009, 09:07 PM   #28
5thseries
biggerthen3
Well, it will get worse, but hopfully the oil you sprayed will minimize the spread... but to prevent anymore damage.. do a quick sheet mettle and rivit fix
Old 01-08-2009, 09:08 PM   #29
5thseries
biggerthen3
Thats what i would do, but you can leave it if you want
Old 01-08-2009, 09:21 PM   #30
Dado 540
Dado 540's Avatar
Did you try asking the dealership what could cause the fogging? Maybe they have a solution for once. Personally i think this fogging is an air circulation issue. wet floor is another issue, maybe hole maybe door seal, or water vapour barrier in the door. Even the smallest hole could lead to wetness. Do you have a sun roof?
