Old 01-05-2009, 02:41 PM   #1
Wingking
Wingking's Avatar
Stroker project complete '85 E30 327i....one issue
She stalls out after about 4 mins.
Without fail.
M20b27 bottom end
m20b25 top end (rebuilt to spec)
swapped out all of the ETA wirring harness to I harness.
Fires right up, idle smoothes out, and stalles.
seems plugs are fouling?
using m20b25 dme.
thoughts?
Wingking is offline   Reply With Quote
Old 01-05-2009, 06:11 PM   #2
NOTORIOUS VR
NOTORIOUS VR's Avatar
are you running stock injectors?
Old 01-05-2009, 06:31 PM   #3
DR.ZED
This sounds like a MAF issue? Disconnect the MAF to run in speed density mode?
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 01-05-2009, 07:05 PM   #4
SamE30e
SamE30e's Avatar
I don't think it will run in speed density. Maybe Motronic 1.1 but my 87 didn't do it.
85 325 - Turbo M52B28.
Old 01-05-2009, 08:46 PM   #5
Wingking
Wingking's Avatar
yes I am.
looking to upgrade asap tho...19lb fords on the way.
Old 01-05-2009, 08:47 PM   #6
Wingking
Wingking's Avatar
have a spare maf from a SETA..unsure if that'll make a diff tho...
Old 01-05-2009, 08:49 PM   #7
Wingking
Wingking's Avatar
forgot to mention, plugs are soaked...seems to be flooding what the mother eff?
Old 01-05-2009, 10:21 PM   #8
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Flooding... sounds like you dont' have the oil return tube seated properly... double check that. If it's gas that's flooding it, could be that it's not getting enough air somehow, make sure the AFM (no maf's in this car) is opening right... make sure the ICV is buzzing and operating properly, make sure that the TPS clicks as soon as you open the throttle body.
Try all that.
