Old 01-03-2009, 06:07 PM   #1
328IScreamer
328IScreamer's Avatar
what clutch should I get for e36 m3 and where in windsor
I have a 99 e36 m3 and it is in need of a new clutch. I was wondering if oem is the best route or if I could get away with something else. There seems to be some good prices on ebay but I wouldn't know the first thing on reputable companies for cutches. I would like to stay away from the dealership but if thats the best route thats where i'll go. I was wondering if anybody from windsor could recomend a good place in the area that would be able to do the clutch.
Old 01-03-2009, 09:55 PM   #2
EstorilM3
Stay with OEM from the dealer in this case, and maybe even have them replace it if there are no good BMW independent garage there.
This way, you're assured of at least one year warranty on parts and labour.
Tranny shops could also do the work, but you should make sure they've done BMW work before.
Also, don't be surprised if the mechanic tells you that you need other bits, like the flywheel.
So, you found a M3, huh? Or am I mistaking you for someone else here?
EstorilM3 is offline   Reply With Quote
Old 01-03-2009, 10:02 PM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
yep found one
its in good shape and interior is mint only catch was the clutch is worn out. I talked to the dealership in windsor and they pretty much told me it would be smarter to not bring it to the dealership. Apparently the oem m3 clutch is not sold as a package everything is sold seperaltly so it ends up being very expensive and he estimated around 1000 in labour. I'd consider it just to have the piece of mind but if i could get a better clutch elsewhere for cheaper and find a reputable garage i'd probly rather do that.
flickr
Old 01-03-2009, 10:03 PM   #4
craigIS
A.K.A. crossfire291
craigIS's Avatar
sorry posted that on a buddy's account this and the above post were actually by 328iscreamer haha
flickr
Old 01-03-2009, 10:59 PM   #5
EstorilM3
Call Turner. They'll set you up with the Sachs clutch kit. Don't get the racing clutch...not the right type for normal daily driving.
http://www.turnermotorsport.com/html...Cat=Drivetrain
Call Don at Autotrend in Toronto to see if he can have it installed for you. He's at 416-696-2277...assuming you can drive it there.
If he cannot, take it to a tranny shop nearby with your parts-in-hand...hopefully, they'll do the job without biatching (they usually have their own parts and are reluctant to put in something they're unsure of or don't make money on).
Where did you get the car?
Is it in reasonable shape?
Mileage?
Old 01-03-2009, 11:07 PM   #6
jameswbl
get UUC motorworks flywheel and upgrade to M5 clutch...check their www
jameswbl is offline   Reply With Quote
Old 01-03-2009, 11:20 PM   #7
1BADBMR
I really don't see any point to upgrade your clutch. The OEM clutch is your best bet, unless you have or plan to go forced induction.
_____________________________________________
98 M3 Sedan (SOLD)
06 Yamaha R6 (SOLD)
04 Honda Civic (Beater)
93 318i (SOLD)
1BADBMR is offline   Reply With Quote
Old 01-04-2009, 12:23 AM   #8
328IScreamer
naw don't plan to go forced induction the only reason why I was thinking about going aftermarket was because it is often cheaper than oem.
I won't be able to make it up to toronto to pick up or have anything installed as my vacation is over but if turner ships then hopefully I can find a place that can do the work.
This is where you windsor ppl chime in does anyone know a place in the area??
Old 01-04-2009, 01:22 AM   #9
E36White
talk to sam at alpina - wyandotte and strabane tell him bader (white 325i) sent u.
E36White is offline   Reply With Quote
Old 01-04-2009, 10:01 PM   #10
328IScreamer
I ordered the sachs clutch kit
i'll have a look at that shop in windsor and i'll tell them bader sent me haha
Old 01-05-2009, 03:26 PM   #11
kprocyk
clutch replacement in windsor
Hi
i have a 1995 M3 and replaced the clutch myself with the UUC lite weight flywheel and m5 clutch set-up, so far it's been great, email off board and i will put you in touch with a BMW factory tech that does work on the side
Kris
kprocyk is offline   Reply With Quote
Old 01-07-2009, 03:16 PM   #12
328IScreamer
e36white,
I just called alpina and asked them for a quote to change the clutch on an m3 and the first thing the guy said was...
"what is an m3" :s
Old 01-10-2009, 08:40 AM   #13
bmwmmn
bmwmmn's Avatar
Screamer, the ONLY shop in Windsor where I would take my car for that type of work would be: http://www.oandoautoservice.com/cars.php
and talk to the owner Ozvat aka Andrej. Check with them, hopefully it helps.
bmwmmn is offline   Reply With Quote
Old 01-10-2009, 05:51 PM   #14
328IScreamer
ok i'll give o and o a shout on monday
Old 01-10-2009, 06:02 PM   #15
spoony_prelude
Eurowerke
spoony_prelude's Avatar
in all honesty if you want to get bang for you bucks check out UUCmotorwerks.com when i did my M swap, I bought a stage 2 lightweight aluminum flywheel 8.5 pounds, e34 M5 clutch. Comes with heavy dutie pressure plate and release bearing and sometimes theyll throw in the stainless steel clutch line for free, i had to pay 25 bucks for it but anyways i think it came out to being like 1200 to my door! Defenatly worth it!
2011 M3 coupe/moonstone/fox red
