Old 12-24-2008, 09:09 AM   #1
doogee
doogee's Avatar
Yellow Under Oil Cap
Was checking and topping off my oil this morning when I noticed the bottom of the oil cap had yellow gunk on it.
Looks like mustard. Did some reading and a lot of people suggest a blown head gasket.
But, couldn't it just be condensation? It never did this in the summer or fall. Suddenly it happens in the winter.
Checked the dip stick and its fine.
Dakar M3 Track Build Thread
Old 12-24-2008, 09:46 AM   #2
Jon@Bimmersport
Jon@Bimmersport's Avatar
check your PM
Old 12-24-2008, 10:04 AM   #3
sthomas
BMWCC 4928, BMWCCA 349578
Yellow on the valve-train is a sign of coolant in the oil. I assume it is the same for the oil cap. Typically a leaking head gasket...
2002 540i M Technic
1993 325is RIP
sthomas is offline   Reply With Quote
Old 12-24-2008, 04:52 PM   #4
morpheus
Its most likely an accumulation of moisture in the oil if you tend to do short trips. This in not allowing engine to reach operating temps and the moisture in the oil cannot evaporate and get out through the pcv. With time, moisture accumulates and when there's enough of it in there, oil can turn to sludge. You can change your driving habits or change your oil more often to remedy to this. This problem tends to only appear in the winter time.
morpheus is offline   Reply With Quote
Old 12-24-2008, 07:31 PM   #5
doogee
doogee's Avatar
This is what I've been figuring. I know I have a little gunk in my coolant but I'm also sure its just from WaterWetter. It tends to do that. I think if it were a headgasket I'd know for sure.
But I took it for a huuuge drive today. Went through half a tank on the highway. So I'll check it out tomorrow and I bet it's all cleared up.
I better stop the short journeys.
Old 12-24-2008, 10:42 PM   #6
archrival
E36 Addict
archrival's Avatar
morpheus is bang on! dodges have this all the time especially due to the oil fillers being external alot of the time...purely condensation noticed more with short drives
archrival is offline   Reply With Quote
