12-22-2008, 04:08 PM
#1
Car: 98 328is / Volvo S90
perhaps a diet is in order?
Hey guys,
I have a 328is 1998. I've been thinking, instead of trying to add 1-2hp here and there while spending money, maybe i should try and get her to lose a few pounds. I know I can get some weight out easily from the rear by removing the rear bench,spare(already out) remove all the carpeting and insulation from the trunk but Id also like to shave some weight from the front of the vehicle. Is there anything that can be removed without going too hardcore like pulling door panels, the dash , window regulators and such. Thanks, also id like to hear from other with the same setup as me, h&r race springs and koni adjustable shocks. I've been experiencing some understeer now that the suspension is soo stiff. Anyone else feeling this?
Thanks guys
12-22-2008, 04:24 PM
#2
Car: 2007 335i
most comonly people get rid of their A/C, power steering, and start shifting things to the back, like the battery. Removing the Window washer fluid system, getting a CF hood. Changing seats will also remove quite a bit of weight.
With regards to your understeer problem... a front diffuser will help you a lot... I don't know who makes them, but they make massive difference.
12-22-2008, 04:59 PM
#3
JUICY J CAN'T
Car: S54 titties
wait, what? your e36 is understeering? umm. you're doing something wrong.
12-22-2008, 06:52 PM
#4
Stance is Gay.
Car: '06 325i
E36's have understeer built in to them for safety. You can learn how to counter it, or just get adjustable sway bars.
12-22-2008, 07:01 PM
#5
Car: '00 540i
Understeer? Change the settings on your adjustable shocks.
93 325is - sold!
2000 540ia- sold!
12-23-2008, 12:29 AM
#6
Im going to put sway bars on next spring, try and shave off a few pounds and hopefully it will be better.
12-23-2008, 12:45 AM
#7
Car: 330ci SC, M5 Touring
Originally Posted by MiroE36
"start shifting things to the back, like the battery"....
In a bimmer? You dont say!!!
12-23-2008, 01:54 AM
#8
on to the next 1
Car: 323ci
LOL
Originally Posted by TNation
Yo man, I got $6000 in my bank account, and I could buy any car i want
Ya man with $6000 in the bank, you're really balling arnt ya
12-23-2008, 02:14 AM
#9
Hooked on Boost
Car: Turbo 328is
swap out your seats for some non-power, non-heated racing seats.
Swap out your wheels for some light weight racing wheels like kosei.
Get yourself a lightweight battery
swap out your exaust for something aftermarket that is much lighter
12-30-2008, 04:04 PM
#10
Sex Wagon
Car: E36 / E91
Originally Posted by alpine86
Do we really need an Ipad???
Originally Posted by BigD
Only if you have an iVag.
12-30-2008, 08:07 PM
#11
Car: Z3, M3 (e36)
Your exhaust system is quite heavy too... a catback UUC system U muffler will save you almost 30 lbs.
A lighter battery will also save you at least 20 lbs.
Other then that you've pretty much done in the back.
In the front, the AC system is quite heavy, its about 55 lbs.
Removing the sunroof motor and replacing bolting/wealding the pannel into place will also save you some weight.
Front seats replaced with bucket seats can be also quite dramatic as they are about 70+ lbs each. You can remove over 100 lbs just by going to a sparco or other seat.
Once you take care of the big stuff, you can get more thoural and remove the sound system, speakers, amps, headunit, wiring. That will be close to 70-80 lbs.
Even the suspension can use light weight parts, e.g. using aluminum control arms. Using floating rotors also saves weight too.
Light weight wheels were also mentioned, but you can't stress enough reducing unsprung weight has at least 3-4 times the impact! E.g. going from 25lbs stock wheels to 17lbs wheels reduces each corner by 8 lbs or 32 in total. But that has the effect of reducing weight by at least 90-120 lbs when it comes to braking and acceleration. Same goes for a flywheel although its only noticeable in lower gears.
The sky is the limit...
Regards,
T.
T.
12-30-2008, 10:56 PM
#12
Driving in the fast lane
Car: e38 Sport, e63
battery at the rear right -- for weight balancing!
'04 645cic (for sale)
'05 GMC Sierra SLT Z71 CCSB 4x4
'02 Regal LS
'00 740i Sport
'06 330cic vert ZHP (sold)
'00 323i (sold)
'99 328cic vert (sold)
