Old 12-18-2008, 02:21 PM   #1
preet006
auto to manual swap.
Anyone have any idea how much it would cost to do a auto to manual swap on a 328is, including labor and parts? Thanks in advance.
preet006 is offline   Reply With Quote
Old 12-18-2008, 04:09 PM   #2
R.S.C
Imaginary Player
R.S.C's Avatar
From what I know it's just about 1500 with parts and labor
Yamaha R6 + Alpine White F30 + Techno Violet e36
R.S.C is online now   Reply With Quote
Old 12-19-2008, 04:48 PM   #3
fastasleep
I thought it was much more expensive. Could you point me in the direction where it could be done so cheaply pls? I'll be in need of this swap when my auto dies
fastasleep is offline   Reply With Quote
Old 12-19-2008, 10:58 PM   #4
hellrot_M3
hellrot_M3's Avatar
call up RMP, they are great and honest
RMP Motors For The Win!!!!!
hellrot_M3 is offline   Reply With Quote
Old 12-20-2008, 10:45 PM   #5
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
I'll do it for $2000... just finished one
Old 12-21-2008, 04:39 PM   #6
fastasleep
I'll keep that offer in mind. thnx
Old 12-21-2008, 06:39 PM   #7
Trekz
i got clutch pedal and all the other crap you will need inside my old car thats going to be scraped you can have any of it if you come rip it out yourself
Trekz is offline   Reply With Quote
Old 12-23-2008, 08:24 AM   #8
rider-.
i did one for around 600$ recently.. did it in my garage with one of my buddies... pretty easy job to be honest.. its just pulling the auto tranny out and putting a 5 or 6 speed in its place.. add a very small amount of wiring to the picture and uve got yourself a 5 speed swap....
Old 12-23-2008, 01:31 PM   #9
v_bimmer
Jailbait FTW
v_bimmer's Avatar
yeah i agree, the best way to do this swap is by yourself
Old 12-23-2008, 03:19 PM   #10
preet006
anybody wanna help me pull the parts out of Trekz car and put it into mine? Beers on me, lol!
Old 12-23-2008, 03:59 PM   #11
INFAMOU$
INFAMOU$'s Avatar
It shouldn't take you long at all..
Take out the clip holding the clutch pedal line at the firewall in the engine bay.. (down by the fuse box) This line is what feeds the slave cylinder (treks has a slave cylinder as well).. you will need to take the hard line out after you take the clip off!
Inside the car.. undo the 4 main bolts (13mm) against the firewall and the one bolt underneath facing upwards to release the brake/clutch pedal assembly...
Then back in the engine bay you can then take the line from the master cylinder that runs into the master of the clutch pedal.. (you can use your existing master cylinder as the nipple is there)...
Ask treks if he still has his tranny mount and driveshafts as you will need those as well...
Crawl under the car and grab the rear shifter bushing that is directly behind the hole where the shifter goes through the floor (I think he has the interior out so you may be able to get it easy enough from inside the car reaching down through the hole).. it's cylindrical in shape and should pry right out..
Then all you will need is a clutch/flywheel and trans with shifter good luck!
Old 12-23-2008, 10:54 PM   #12
Trekz
and its easy to get to everything in the engine bay because engine is out with the tranny. I need the driveshafts so they are not for sale, but i do got a spare tranny
