Old 12-16-2008, 06:43 AM   #1
doogee
doogee's Avatar
BMW timing lock tools
I need to replace the seal in my Vanos and wanted to give it a go myself rather than pay for a couple hours labour at a shop. But I don't have the tools to lock the cams and crank.
So if anyone happens to have them around, I'd really appreciate it if I could borrow or rent them. Don't really feel like waiting on buying a kit off the net since I probably wouldn't use them again.
So I'm looking for:
Camshafts lock blocks
sprocket turner
crankshaft lock pin
camshaft tensioner lock pin
Any help would be great, Thanks.
Dakar M3 Track Build Thread
Old 12-16-2008, 08:22 AM   #2
kenmar
There's a way to remove/install cams without the special tools. It's described on the PelicanParts.com website.
Old 12-16-2008, 08:36 AM   #3
///tyron
///tyron's Avatar
he's talking about timing the cams. You definetly need the cam lock tools to time your engine %100
///tyron is offline   Reply With Quote
Old 12-16-2008, 03:25 PM   #4
doogee
doogee's Avatar
I dont need to remove the cams. Just need the tools or something similar to lock the cams and keep them from moving so I can unbolt the sprocket on the vanos.
I'll check out pelican parts for something.
Old 12-17-2008, 09:00 PM   #5
doogee
doogee's Avatar
No one has these?
Old 01-01-2009, 10:14 PM   #6
PROJECT_E36
If you've never done this I wouldn't suggest doing it. You don't need 2 remove any gears off the cams the vanos slides in and out. Your just going 2 have to do the timming again.
-Jakub
PROJECT_E36 is offline   Reply With Quote
Old 01-02-2009, 01:34 AM   #7
doogee
doogee's Avatar
Yup, it's most likely going to Bimmersport.
Old 01-02-2009, 03:26 AM   #8
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
BMP Design sells them for $500 http://www.bmpdesign.com/product-exe...earch_model/56
Grow up and move on.
