Old 12-10-2008, 04:42 PM   #1
Dado 540
Dado 540's Avatar
Question Engine Washing
Hey fellas,
Do you wash you 5ers engines? How do you go about it, with all the electical and ECU in there it scares me to plash it with water.
Old 12-10-2008, 05:18 PM   #2
prince1
on to the next 1
prince1's Avatar
Send a message via MSN to prince1
Ya I was wondering about this as well
prince1 is offline   Reply With Quote
Old 12-10-2008, 05:21 PM   #3
Gamite
Gamite's Avatar
I just splash it.
I don't use any kind of pressure washers, just the hose
www.gamite.net
Old 12-10-2008, 05:41 PM   #4
europrince
^ i did the same..plus some elbow grease.
Old 12-10-2008, 09:54 PM   #5
Dado 540
Dado 540's Avatar
What about the ECU, the starter, alternator, . . .?
Old 12-10-2008, 10:42 PM   #6
MiroE36
MiroE36's Avatar
my friend just hoses down his engine then uses a cloth to polish it (taking off most of the dirt). He literally hoses down the whole engine bay, then gets to work... then just starts the car and moves on... it never affected anything. Mind you this is a honda civic, so I don't know if the same is correct for BMWs
Old 12-11-2008, 12:02 AM   #7
Been pressure washing the engine bay of both 5ers once a year since we got them. Haven't had any problems and it keeps the engine bay looking like this
Old 12-12-2008, 05:04 PM   #8
328i Cab
Pressure washers are generally better (because you use less water and can control the flow a bit easier). Just don't spray the electrical components directly, especially the ECU, throttle body, mafs, alternator etc. Seen a few cars get a bit of water in the intake (happened on my cadillac back in the day) - just let it run for a few mins and it should burn off. Just use as little water as possible.
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
Old 12-12-2008, 05:15 PM   #9
Gamite
Gamite's Avatar
But pressure washers can potentially squeeze their way into seals that you don't want water to get into.
Use a mild engine degreaser and a paint brush to loosen the dirt.
www.gamite.net
Old 12-12-2008, 05:47 PM   #10
doogee
doogee's Avatar
Brake caliper cleaner works well too.
Dakar M3 Track Build Thread
Old 12-12-2008, 05:59 PM   #11
///Maluco
5erholic
///Maluco's Avatar
I use a pressure washer and dry it using compressed air....no problems here!
///Maluco is offline   Reply With Quote
Old 12-12-2008, 06:36 PM   #12
328i Cab
Yes, use a soft brush and don't hold the pressure washer for any length of time over any area with electronics. Use it in a quick back and forth motion over the area (hope that makes sense).
Old 12-14-2008, 07:45 PM   #13
Trouble65
Sorry Dinan_M5 pressure washing is the worst possible way to wash your engine bay. The high pressure will eventually find a weak spot in rubber seals and destroy them. I always wash my engine bay with some type of degreaser agent followed by warm water and soap. After that I rinse the engine compartment and use compressed air to get rid of the remaining water.
Old 12-14-2008, 08:06 PM   #14
rider-.
i use tireshine on all the plastic parts... hose everything else down.. turns out looking nice
Old 12-14-2008, 08:10 PM   #15
slimjim
Almost Sideways
i power was the shit out of my engine bay in the e30, never had any problems, i normally just wrap a bag around my cone filter.
