Welcome to!
Old 12-07-2008, 12:49 PM   #1
s52 & 5 spd e36 swap
im getting a s52 swap done this week or next and besides upgrading the cooling system and replacing valve cover gasket if needed, which other parts should i need for the swap. Obviously i need to replace the engine and transmission mount and i am unable to decide on which mounts to use. i have been looking at the kits from turner motorsports and i cant decide. any help is greatly appreciated. thanks
korne30 is offline   Reply With Quote
Old 12-07-2008, 04:03 PM   #2
the misanthropist
BigD's Avatar
Replace every wear item (water pump, belts, even headgasket if you can) and sensor you can afford to. It'll add a lot of money to the swap but the difficulty and expense of changing any of these after the engine is in, will make you want to tear hair out of your asshole for not doing it when the engine was out of the car.
Old 12-14-2008, 08:47 AM   #3
Propeller Head
bigfeller's Avatar
Oil Pump Nut
The S52 is an exceptionally stout, reliable, and bullet-proof motor. There are very few internal weaknesses. That said, the Germans haven't figured out how to make anything out of rubber or plastic, so all of your accessory belts, pullies, gaskets, etc should be replaced now while it's cheap and easy- as already mentioned.
The S52 has only one design flaw that can result in catastrophic engine failure (other than the shitty cooling system)- the Oil Pump Nut. Go over to and do a search for Oil pump nut to learn more. Definitely address this while the engine is out of the car.
'97 M3
SOLD- Now Enjoying Honda Civic
bigfeller is offline   Reply With Quote
