Old 02-18-2009, 09:28 AM   #46
chromius
chromius's Avatar
I thought your A/C didn't work anyway? Wasn't it 'Rudy disabled'
Old 02-18-2009, 11:01 AM   #47
It was.. I can't figure it out actually. The relay for the AC fan was pulled, the wire to the compressor is cut, but even with those refitted, the blue A/C button doesn't light up. As far as I can tell from the wiring diagram, it should light up and I should get 12V at the high / low switches.
I was hoping to keep the A/C, replace the clutch without removing the compressor and I have another A/C fan too, but it looks like the line that moves around the strut tower needs to be straighten and run along the fender, so I'll need a custom line made or something. So for now, I'm going to drain the system, plug the lines the best I can and hopefully reinstall everything in the summer sometime.
Seems a shame since I have a $2100 bill from Rudy for retrofitting the system to R134a and what not. :p But it wasn't my money, so meh.
Old 02-18-2009, 11:17 AM   #48
Fel
Not Banned
Fel's Avatar
I hate you.
At least you prevented me from spending money that I can really use elsewhere.... that wheel is so sweet.
Old 02-18-2009, 11:20 AM   #49
^ HAHAHA. I'm happy to oblige.
Can you believe I got it home, left it in the box and put it in the basement? No goodies until the work is done, lol.
Old 02-18-2009, 12:55 PM   #50
e30_kid89
The Afro-stig
e30_kid89's Avatar
What turbonator/manifold are you planning to use?
Old 02-18-2009, 02:40 PM   #51
524td mani, I've got a GT32 twin scroll that I may use, or find something that fits better when I've got the manifold on.
Old 02-18-2009, 04:12 PM   #52
oldskool3
oldskool3's Avatar
So you decided against using your other mani?
Old 02-18-2009, 05:14 PM   #53
That's the only mani's I got.
I got the A/C evacuated today for $60, so I'm good to rip out the A/C system for now. Any tips?
Old 02-18-2009, 05:21 PM   #54
oldskool3
oldskool3's Avatar
For some reason I thought you had bought an ebay mani
Old 02-18-2009, 05:24 PM   #55
Nope. I'm going to use the 524td for now, document the power, etc, and then if I find it necessary move to a really good quality one, like 666 fab and compare the difference. But if this puts down enough power to feel fun, then I'll likely leave it. I looked at a TCD log manifold and can't see how this will flow any less, and the 524 is split pulse. :? :?
Anyway, time will tell if it works out.
Old 02-18-2009, 05:29 PM   #56
e30_kid89
The Afro-stig
e30_kid89's Avatar
It's good, but i think since the flange is so close to the valve cover you are limited to what size turbo you can run. I think you can fit I decent one with a on-center turbine housing..
Old 02-18-2009, 05:30 PM   #57
Yeah, worried about that. Might get an extra split flange for a spacer. Think that would work?
Old 02-18-2009, 06:08 PM   #58
e30_kid89
The Afro-stig
e30_kid89's Avatar
It should.....I think you would have enough room above to raise it up a few inches.
Old 02-18-2009, 08:33 PM   #59
SamE30e
SamE30e's Avatar
I've got a nice Garrett in my garage that I don't plan on using lol.
85 325 - Turbo M52B28.
Old 02-18-2009, 10:43 PM   #60
Which one do you have? In a month or so when I have the manifold on and measurements taken, I might be interested.
