Old 12-06-2008, 02:19 PM   #1
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Quick Pics of my turbo 328is before I put it away for its winter sleep
Hey guys, here's some quick pics I just took of my Turbo 328 before storing it for the winter, as you can see its snowing at the moment so these were super quick. Also aesthetically the car could use some touch ups but they will be waiting until spring.
Engines Mods are as follows:
Custom turbo system built and tuned by me : )
t3/t04e 60 trim turbo, .82 a/r hotside
SPA manifold
Tial 38 mm Wastegate & Tial 50mm BOV
3" Aluminum charge piping (routed over the subframe)
Big ass Treadstone Performance intercooler
48 lb Accel Injectors
TEC3r hardwired into harness (no P&P)
AEM UEGO
3" custom exhaust all the way back, 2 resonators, no cats and borla 3" straight thru muffler
99 M3 Cam
M50 intake manifold
UUC underdrive pulley
Other Mods
ZM3 Short Shifter
UUC Stage2 Lightweight Flywheel 8.5lbs
BMW E34 M5 Sachs Clutch (will be swapped out in spring for something with some more grab)
3.23 LSD Diff
Ground Control Track / School coil-over kit Front 600lbs/ rear 700lbs
Adjustable Camber/Caster
Racing Dynamice Front Towerbar
Eibach Anti-roll Bars
BMW OEM X-brace
Rear TowerBar
Front e46 330 Calipers and Coss drilled Brembos
Stainless Steel brake lines
M3 Body kit with M side moldings, M side Mirrors
Carbon Fiber Hood
AC Schnitzer 17" x 8.5 Type 1 wheels (new this year as well)
feedback welcome : )
http://www.foldingtrailers.ca
Old 12-06-2008, 02:30 PM   #2
slimjim
Almost Sideways
no ceremonial donuts?
very nice ride. and u didnt jump on the clear side marker band wagon, nice to see.
Old 12-06-2008, 03:14 PM   #3
PedroBMW
Hooked on Boost
PedroBMW's Avatar
I've logged plenty of donuts before the snow started
Actually to be honest, with 235 falkens and cold days (even before snow started today) I have no traction in boost in 1st, 2nd or 3rd, even a 4th gear pull can be hairy.
I actually did jump on the clear corners band wagen , but my passenger side one was broken so I went back to ambers (my rears are still red/clear), I don't really mind it either way, but for some reason on my car I don't like the way the amber looks with the carbon fiber, just doesn't look right, I think I'm going to try smoked when I replace them this time.
Old 12-06-2008, 03:53 PM   #4
Michel
Michel's Avatar
very nice! How much boost are you running? and hp?(roughly)
This is exactly what I would love to do in about a year if I get an internship.. So I will need your help!
Old 12-06-2008, 05:02 PM   #5
PedroBMW
Hooked on Boost
PedroBMW's Avatar
I was only running 8psi right now. I'll be cranking it up in the spring, need to buy some dyno time do do some tuning and winter has been coming to quickly this year.
I should be making 400whp and somewhere in the neighbourhood of 1 bar of boost when its all said and done.
Old 12-07-2008, 01:58 AM   #6
E36White
pedro i have a pair of clears that were sent to me by mistake ..i wanted smoked for a sedan i received clears for a coupe..im in windsor btw let me know if ur interested!
oh..and we def need to organize a bmw meet come spring...sick car!
E36White is offline   Reply With Quote
Old 12-07-2008, 11:33 AM   #7
///tyron
///tyron's Avatar
very nice setup. any pics of the charge pipe routing? Did you make the down pipe yourself?
///tyron is offline   Reply With Quote
Old 12-07-2008, 08:34 PM   #8
denisemichel
AMG LOL
denisemichel's Avatar
turbo is nice!
01' BMW 530i Sold................................03' Lexus GS430 Sold...........................06' BMW 750i
denisemichel is offline   Reply With Quote
Old 12-07-2008, 11:12 PM   #9
MiroE36
MiroE36's Avatar
sweet ride
Old 12-08-2008, 01:02 AM   #10
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Sorry I don't have any pics of the charge pipe routing, I already have the car stored away so I cant take any, PM me in the spring and I'll show you. Basically the turbo is clocked such that the discharge is pointed up, I have a cast aluminum 90 degree bend welded directly on the compressor housing. The charge piping comes off the 90 and runs below the manifold and then bends down right before the AC compressor, then it just squeezes threw by the sway bar and to the intercooler. It takes some time to mock everything up to run them this way but it is possible. My car is way to low for me to have run them under the subframe like most of the kits do, I already scrape my X-brace on the ground so I couldn't afford to have anything else lower than that.
Yes I made the downpipe, that also takes a bit of slow mockup to do with 3" if you want to make sure you don't sacrfice any ground clearance and also not have any vinrations from pipes touching frame, its slow but easy enough. For the wastegate tube, I started with the SPA peice but it wouldn't fit past my turbine housing so I just chopped it up and made that too. I really like the way I have it routed, the entire packaging of the turbo, downpipe, WG tube, WG, Oil Drain, and X-brace are very tight but look very sweet, I'll try and remember to post dsome pics of it in the spring.
Old 12-08-2008, 01:43 AM   #11
AceOfSpades
AceOfSpades's Avatar
very nice ride! Those tints are FTL tho!
Old 12-09-2008, 11:54 AM   #12
///M-TRD3
Modeldater
Wow, car looks great. It's so refreshing to see a cleanly modded not overdone BMW. Car really looks excellent Pedro. If it were me the only thing I would do is go back to OEM tails with the amber, to match upfront, but I'm a amber fan on black, I like the minimal contrast it offers.
///M-TRD3
Old 12-09-2008, 12:25 PM   #13
lukeh
runnin' capless
The one eyebrow is a nice touch.
Looks great man.
lukeh is offline   Reply With Quote
Old 12-09-2008, 10:40 PM   #14
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Thanks for the compliments guys!! very much appreciated,
to be honest the amber has grown on me, I still have amber tailights at home, I may toss 'em back on and kick it old school again for a bit.
The one eyebrow has been like that for a long long time now, its sort of become an ongoing joke, so I haven't done anything about it. I figure I'll cross that road when I get ZKWs again.
Old 12-16-2008, 02:25 PM   #15
TNation
man your car is sweet
how much did it all cost you to do the whole turbo deal yourself? did you have to build your engine at all for it?
TNation is offline   Reply With Quote
