Old 12-02-2008, 08:21 PM   #1
1sick318
1sick318's Avatar
how has m50 intake
hey guy just wanted some opinions on the m50 intake manifold is it worth getting and how much horsepower would i get
1sick318 is offline   Reply With Quote
Old 12-02-2008, 09:16 PM   #2
doogee
doogee's Avatar
I highly recommend it. I put it in this summer using Eric's kit from m50manifold.com
It was pretty easy to install, just time consuming.
You can expect a deeper sound, around 20-30rwhp with an intake. Proven with dynos.
Most noticeable difference is the car doesn't run out of breath past 4000rpm. It just keeps pulling and pulling.
Dakar M3 Track Build Thread
Old 12-03-2008, 01:14 PM   #3
1sick318
1sick318's Avatar
thinking of picking one up off a 320
Old 12-03-2008, 01:16 PM   #4
doogee
doogee's Avatar
Yup as long as its from an OBDI car, it'll work. Again, highly recommend this mod.
Old 12-03-2008, 06:11 PM   #5
98Dinan3
98Dinan3's Avatar
^^^ this info is WRONG. The "M50" manifold off the e36 320 is NOT the same part as the one off the the 325 and S50 M3. You'll end up with a major vac leak, I can guarantee it... Source one from somewhere else...
Edit... this mod doesn't work on the 318... unless you've got an OBDii 323, 328, or M3, you c annot swap on the m50 manifold.
Old 12-03-2008, 06:31 PM   #6
doogee
doogee's Avatar
Wow my bad. Whats the difference between the two? I noticed the ribs on the side are a little different. Thought being an M50 motor, it would of been the same manifold.
Old 12-03-2008, 06:32 PM   #7
1sick318
1sick318's Avatar
no its not for a 318 i had a motor swap done in november my car is a 318 but i have a
s52 m3 but thanks for the info guys really helps. so the 320 dosent work a
thank god i dindt buy it thanks guys
Old 12-04-2008, 07:37 AM   #8
Trouble65
Good mod. However I would purchase the hole kit. You might save $100 if you look for parts. Do it properly don't take short cuts.
