Old 12-02-2008, 11:14 AM   #1
richmak
richmak's Avatar
where is air filter (not cabin filter) located?
Looking to replace the airfilter on my 2003 525iT. Appreciate information on where the air filter (not the pair of cabin filter on top once the hood is opened) is located.
Thanks.
richmak is offline   Reply With Quote
Old 12-02-2008, 11:34 AM   #2
Gamite
Gamite's Avatar
The airbox is that black plastic box to the right of the engine behind the headlight.
www.gamite.net
Old 12-02-2008, 02:48 PM   #3
richmak
richmak's Avatar
Thanks.
Old 12-02-2008, 07:04 PM   #4
richmak
richmak's Avatar
How often should I replace the air filter? Is it worth to spend $65 on the K&N filter?
Old 12-07-2008, 08:35 PM   #5
Qube
Depends on your driving. Usually a year.
and... no. Don't. Change it to another intake, but not to a K&N panel, not for that price.
Old 12-08-2008, 12:58 PM   #6
Gamite
Gamite's Avatar
I think you can get K&N for about $40 from autopartsway.com
I picked up a pair for the M5.
www.gamite.net
Old 12-08-2008, 01:20 PM   #7
richmak
richmak's Avatar
From what I read, most people are leaning towards using the OEM filter and change it more often than using the K&N filter which may lead to more maintenance.
Old 12-08-2008, 01:21 PM   #8
MLue1
MLue1's Avatar
FYI: I've read at BF.c that the oil from the K&N filters can contaminate the MAF sensor... resulting in a CEL until the MAF is cleaned or replaced.
Mark
'99 E39 540iT
Old 12-08-2008, 01:26 PM   #9
Qube
Wow! I'm surprised you'd use a K&N-panel-maf-gunker filter. I'm guessing you're saving for a true intake in summer.
Usually:
1. You need to clean your maf during the early runs
2. Not many people clean it after the year
3. Doesn't give enough sound or gain for the price
Granted... 40 bucks if Canadian, I'd do it... Once.
Old 12-08-2008, 01:41 PM   #10
Gamite
Gamite's Avatar
the AA intake uses K&N inserts. so. I don't know if it's going to cause problems. We'll see I suppose. I don't know which intake I'm going with yet.
www.gamite.net
