Old 11-25-2008, 11:55 PM   #1
bAhN_Burner
bAhN_Burner's Avatar
What MP3 headunit can match my e36 HK 10 speaker 320watt system
Hey all, I'm just trying to figure out which MP3 headunit will be best for my 10 yr old Harmon Kardon 10 speaker 320 watt system on my e36 328is... i do not now much about decks but i do notice they usually have only 50 watts times 4 im assuming 50watts through 4 channels? but if i have 10 speakers will i get the full sound, anyone??
bAhN_Burner is offline   Reply With Quote
Old 11-26-2008, 12:03 AM   #2
your e36 has an amp, so its not all about the headunit's wattage. Are you running the stock speakers and stock amp? Or are you running aftermarket speakers?
Old 11-26-2008, 12:12 AM   #3
bAhN_Burner
I am running all speakers stock and amp (HK) I just want to put in a MP3 headunit cause im sick of the radio, i was wondering if any MP3 headunit will produce the same sound quality as my OEM headunit did or even better
Old 11-26-2008, 01:26 AM   #4
elroy
go alpine
elroy is offline   Reply With Quote
Old 11-26-2008, 11:11 AM   #5
Gamite
Gamite's Avatar
It does not matter what wattage the head unit is if you're using an external amp. What you're looking for is good signal processing. Alpine is good, but if you're really picky, go with their older models, which seem to be better quality than their new stuff.
www.gamite.net
Old 11-26-2008, 01:26 PM   #6
///MG
///MG's Avatar
Go with the same one I have... Alpine CDA 9887r
It has amber/red lighting and a white LCD display. MP3, Ipod controls... it's the best deck out there now in my opinion.
2003 BMW 330CiC CURRENT
1996 Toyota Camry FOR SALE
1998 BMW M3 IN EUROPE
2004 Mitsubishi Galant SOLD
1993 Plymouth Duster SOLD
///MG is offline   Reply With Quote
Old 11-26-2008, 01:50 PM   #7
bAhN_Burner
thanks guys... btw Gamite I have a stock amp Harmon Kardon that came as an option in all e36's, i do believe 320watts, I take it as long as you have any amp i do not have to worry about the headunit wattage only the signal and clarity.... thnks
Old 11-26-2008, 04:12 PM   #8
Gamite
Gamite's Avatar
The amp handles the power. Most head units only give about 60W/channel. Mainly because if you want to have good sound you use an external amp anyways. The headunit gives you the option to turn the internal amp off.
www.gamite.net
Old 11-28-2008, 02:10 PM   #9
NOTORIOUS VR
NOTORIOUS VR's Avatar
9887r? Isn't that a european model? I have the 9887, and the US/Canadian Alpine site doesn't show the 9887r at all.. I do see the 9887r FS in Europe though, seems like the only difference being it has RDS in the tuner.
Anyways... I 2nd that, the 9887 is currently the best sounding Alpine HU out there right now. It's not flashy, has adjustable lighting, has a ton of audio options (EQ, crossovers, TC, etc) and sounds amazing.
