Old 11-19-2008, 01:15 AM   #1
guibo
Question disabling DRL, dash lights always on
i have two beefs with my '90 e30 325i.
1- day light running lights. i want to disable them, they are so annoying because they arent real daylight running lights, they just turn on the lows and turn on the tail lights also. not necessary in the day. how do i disable this?
2- dash lighting always on! what's up with that? i dont need my cluster + buttons illuminated unless it's night and i turn on my lights. how do i fix that?
thansk for the tips
guibo is offline   Reply With Quote
Old 11-19-2008, 01:31 AM   #2
they're the same problem. Fix your DRL, your dash lighting will turn off. Mine is a US car, no DRL
Old 11-19-2008, 09:41 PM   #3
hadesm5
hadesm5's Avatar
since when did e30s have DRL's?
check your relays
hadesm5 is offline   Reply With Quote
Old 11-19-2008, 09:50 PM   #4
check your relays
Post 1990 Canadian models did.
Old 11-19-2008, 10:24 PM   #5
guibo
exactly.
does anyone know where the wiring for the headlights runs, and what could possibly activate DRL?
Old 11-19-2008, 10:52 PM   #6
I suspect its the actual light switch. That's just a hunch though.
Old 11-19-2008, 11:04 PM   #7
andicanada
andicanada's Avatar
it is the light switch i have a europen version and keep some spares only for me lol
Old 11-19-2008, 11:13 PM   #8
I tryed to change the light switch on my friends '91 318, it didn't do anything. I also tryed a light switch from a euro e30, still didn't do anything, so I have reason to believe it is not related to the light switch. Its something in the wiring under the dash.
Old 11-19-2008, 11:28 PM   #9
guibo
you are correct. i also swapped in a switch from a '89 that had no DRL and failed!
i opened the switches, they are identical. i suspect a relay under the dash somewhere. but where?
Old 11-19-2008, 11:36 PM   #10
Must have a light control module like the e34. Did you google it or search on e30tech / r3v?
Old 11-19-2008, 11:56 PM   #11
I did search on both r3v and e30tech way back when... But since their cars are US spec, their wiring diagrams are for non DRL cars. And I'm too noobie for anything electrical related so I gave up
Old 11-19-2008, 11:57 PM   #12
guibo
yes i did quite a bit, i only found a fuzzy wiring diagram
i believe the e30 doesnt have a light control module. normally that module reduces the light strength for DRL. but on the e30, they are just as bright on or off.
i think the factory just found a short cut for canada to make it legal since it was the last 2 years they made the e30 anyway. now i need to find a way to undo the shortcut.
Old 11-20-2008, 12:02 AM   #13
^^ Where did you find that?
Old 11-20-2008, 12:09 AM   #14
guibo
here:
http://www.bimmerwerkz.com/forum/3-s...hts-58472.html
the goal is to locate and kill that diode!
Old 11-20-2008, 12:12 AM   #15
daayummm... Wish that was around two years ago LOL.
Edumacate me a bit on how to read these diagrams... if the diode is gone, wouldn't the whole light system not work?
