Old 11-18-2008, 06:30 PM   #1
Nguyen_E30
0011 0001 1000
e30 problem...need help!!!
so yesterday, i tried opening my door from the passenger side since i was never able to open it from the driver side (bought the car like that) and guess what, i couldnt turn the key.
i cannot open it from the driver and or passenger side. therefore i am screwed.
i'm thinking my passenger side is just frozen? since it has been raining/freezing the last few days. gonna try again later to see if it would open.
if i cant get the door open. any clue as to what i can do to get inside the car? trunk still opens.
thanks, ricky.
Nguyen_E30 is offline   Reply With Quote
Old 11-18-2008, 06:34 PM   #2
matty.dc
matty.dc's Avatar
lol that sounds like a bad problem......you should be able to unlock your car from the trunk....that's what my 325is does..
2013 Ford Edge - Daily Driver
Old 11-18-2008, 06:35 PM   #3
Wannabe
Northwood.
Wannabe's Avatar
if its frozen and as a last resort pour hot water down the window seal around the lock.... but then make sure to drive it for awhile, so the water will evaporate.
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
Old 11-18-2008, 06:48 PM   #4
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
had similar issues this morning.. there is a key broken off in my drivers door so i went to unlock the trunk it was frozen, busted out the burnzomatic torch heated it up carefully for a few seconds it opened but my drivers door with the key broken off in it stayed locked untill I manually pulled up the lock
I was soo happy
86coupe30 is offline   Reply With Quote
Old 11-18-2008, 07:15 PM   #5
Nguyen_E30
0011 0001 1000
i was never able to unlock my doors from my trunk. the lock is messed i think.
Old 11-18-2008, 07:55 PM   #6
slimjim
Almost Sideways
wooot all my locks work!
Old 11-18-2008, 10:43 PM   #7
richie_s999
this sounds stupid but, turn the key the other way...no joke, if I put mine in and it doesn't turn I flip it and the it does, guess one side is more worn
Old 11-18-2008, 11:01 PM   #8
El Gato Liso
El Gato Liso's Avatar
i read once e30s have a built in defroster if the key is turned the other way
and good thing i dont have to deal with the stupid e30 locks not opening this winter D
R.I.P. E30
Old 11-18-2008, 11:23 PM   #9
andicanada
andicanada's Avatar
e30's with winter package have heated door looks at the driver side like the one i have for sale around the look is a heating coil what is conected to the micro switch so hold the switch in there and try to turn after 5 sec. the key will work fine
same happen 5min ago as some ppl. looked at my car and they wanted to see the inside
i love heated looks
Old 11-19-2008, 12:14 AM   #10
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
IIRC all Canadian e30's have heated locks, since they all came with the winter package. Whether or not it works is another question. Another easy solution is to keep the locks well lubricated with silicone spray, displaces moisture so they don't freeze up. I haven't sprayed my beater in a while and it was stiff this morning, time to bust out the spray!
Old 11-19-2008, 01:50 AM   #11
SamE30e
SamE30e's Avatar
I heard its if you hold the door handle up.
85 325 - Turbo M52B28.
Old 11-19-2008, 02:01 AM   #12
El Gato Liso
that too!
R.I.P. E30
Old 11-19-2008, 09:46 AM   #13
or buy a $30 keyless entry!
