Old 11-13-2008, 11:42 PM   #1
Pinto009
tick tick tick sound form my e39
my 1999 528i started ticking on me today it a tick tick tick noise form front passager side i believe but i can also here form underneath could cat on the exhaust tick , i also been getting rough idle at times i think i got a clogged cat but will that contribute to the ticking sound i read many treads about this and the only way so far is to change the oil which i have done to mobile 1 ow40 and they said to drive it hard , do you guys got any recommendation . also when i take the oil cap off when car is running its seems to have a little strugle with same with the dip stick thanks in advance for you reply
Pinto009 is offline   Reply With Quote
Old 11-14-2008, 12:28 AM   #2
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Are we sure it's not the Vanos unit(s)?
95 530i|Modifications - Work.
ACS_DAN is offline   Reply With Quote
Old 11-14-2008, 12:30 AM   #3
europrince
get it scanned, no?
Old 11-15-2008, 02:52 PM   #4
Pinto009
i am pretty sure not the vanos unit i think i many have something to do with the exhaust manifold maybe the gasket if i hit 6000 rpm the sound is gone form couple min then returns after i think it is result of poor oil circulation i will sea foam it see if it helps there no signs on the dash if i get it read will anything pop up what you guys think
Old 11-15-2008, 03:11 PM   #5
Pinto009
here the thing i just picked it up a couples weeks ago and it had no sound at all everything was fine the guy i picked it up from how by the way owns like 5 bimmers told me he got the oil changed at a reliable garage he takes all his cars too . so everything went fine until one day i decide to push it a little hard once as a fellow m3 driver and all when i get back home i hear this sound so i immediately turned it off star researching it found it could be an oil problem called this guy up he gave me the mech number called him up this jackass had no clue what the hell he was doing he put 5w30 semi syntec castrol in the car i almost died when i heard it imeditaly flushed it and put in 7 fresh quarts of Mobil 1 ow-40 this guy did not even change he filter so i got another 3 knocked off the price all in all i got it for a good price is the only reason i still have it so i taught i let you guys know some history to why this is happening
Old 11-15-2008, 06:26 PM   #6
Dado 540
Dado 540's Avatar
WoW i would have killed him. So is the ticking problem gone now?
Old 11-15-2008, 08:38 PM   #7
Pinto009
no still there its anything as hell cant figure it out its much louder near the side of the exhaust manifold and i been getting kick back form the exhaust do you think this could be cause by the cat or something being blocked its although as i sayed before if i hit 6000rpm its compelty goes for a couple of mins what you guy think . exhaust or lifters gong to try uploading the sound on to youtube
Old 11-15-2008, 08:48 PM   #8
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
sound like this?
Or this
Old 11-15-2008, 08:54 PM   #9
Pinto009
a bit of both sound like the top one but can also been herd at the bottom just as the video combination of both videos also my exhaust are shaking when in drive happens randomly some time smooth some times it shakes thanks for the help by the way
Old 11-15-2008, 11:01 PM   #10
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Maybe lifter tick, Some people have had good luck with running thicker oil. In some extreme cases that won't solve the problem and the only remedy will be a head overhaul.
I'd try and take it into a shop for a better opinion/Diagnosis.
Good luck man!
Old 11-15-2008, 11:31 PM   #11
Pinto009
thanks for the help man this forum is the best lot of good guys , the sound went away after using the sea foam stuff that stuff works wonders hope it dose come back . figures crossed and what grade of oil you recommend
Old 11-16-2008, 06:34 PM   #12
Dado 540
Dado 540's Avatar
How do you use sea foam?
Old 11-16-2008, 06:48 PM   #13
Pinto009
its real easy man you pick up a bottle form parts source 12 sum thing the you get your to optimal temp meaning normal driving temp you unattached the brake boost line driver side ofthe engine right on the top can miss it let it suck in slowly 1/3 of the bottle turn the car off wait 10-15 min turn the car on you be able to see the smoke coming out big white clouds form exhaust keep revving till it looks like it almost all gone cleans out you engine real nice here is a youtube how to same thing for the e39 http://www.youtube.com/watch?v=MzqohWTChwY i also put 1/3 in the gas tanks
Old 11-16-2008, 07:23 PM   #14
Dado 540
Dado 540's Avatar
Is this 100% safe for the engine, are there any sideffects?
Old 11-16-2008, 07:27 PM   #15
Pinto009
i did a lot of research and as far as i know its done nothing but good especially BMW if i remember correctly there is a tread on here also that support thing and couples f guys on here swear by it all i know is i cleaned the hell out of my engine driving so smooth now just Google it man you seen the number of people that swear by it good luck
