Old 11-10-2008, 11:52 PM   #16
El Gato Liso
El Gato Liso's Avatar
Originally Posted by propr'one View Post
the car was on E when it didn't want to start, now its on full and starts every time.
Mr. One man all i can say is LOL
R.I.P. E30
El Gato Liso is online now   Reply With Quote
Old 11-11-2008, 12:44 AM   #17
ok, i drove back from ottawa. That's 500KM. I filled up before i left, it was on E when i got home. I'm not going to fill my tank up just cause its under 3/4. If my fuel pump is broken, i'll fix it.
It was on E, not UNDER E, there was gas in the tank. It started today, before i drove it to the gas station(DUH)
Old 11-11-2008, 12:52 AM   #18
I had somewhat the same problem on my Jeep; it would start and run, but would NOT re-start if hot...Only starts cold. Problem was fuel pump...Made the mistake to got one of those cheap aftermarket ones, that lasted a few months and left me stranded in London...Now i put a $700 Bosh one, and its all good...
Old 11-11-2008, 01:54 AM   #19
I put in a 255lph $70 pump from ebay, he still sells them on ebay. that was a few years ago. very good quality pump for the price, minimal work to make it fit. Strong pressure and high flow. Just a thought. You could do away with the 2 pump setup on the eta.
Old 11-11-2008, 03:46 AM   #20
the bosch ones are 200$ from autopartsway. does it say wether you have a delco or bosch fuel pump on the cover?
Old 11-11-2008, 10:12 AM   #21
SamE30e
SamE30e's Avatar
**** it, just get a 255lph in line pump off ebay. It costs 1/4 the price and works the same.
85 325 - Turbo M52B28.
Old 11-11-2008, 10:28 AM   #22
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
99% sure it's the fuel pump relay. Usually a quitting pump makes the car sputter at high RPM's.
Old 11-11-2008, 11:53 AM   #23
can someone post a link to one of these 255lph fuel pumps that work in e30's?
Thanks!
I kindof suspect the relay aswell, but on account of this car is running like a top, and its getting up in mileage, i'll probably replace the fuel pump as a prevenative step.
Old 11-11-2008, 12:24 PM   #24
Here's the one I bought:
http://cgi.ebay.ca/255LPH-FUEL-PUMP-...em140279884363
And here some pics I took during the swap. The kit had everything I needed to swap to the new pump. I had to cut some bits with a hacksaw, that's it.
http://picasaweb.google.ca/jasoncopp...FuelPumpPhotos
Old 11-11-2008, 01:21 PM   #25
Red_Rocket
Red_Rocket's Avatar
Ok so what does it mean when you car doesnt start unless the CEL is on? It has an alarm wired in i have no clue if it works. But once the CEL goes on it always starts. And it takes longer for the light to come on in cold weather.
Red_Rocket is offline   Reply With Quote
Old 11-11-2008, 01:27 PM   #26
e30_kid89
The Afro-stig
e30_kid89's Avatar
If your CEL isnt showing it means your main relay for your harness isn't turning on or its on it way out. Main relay controls weather the ECU is on which controls the fuel/spark, so yeah you'll wanna make sure its on all the time.
Old 11-11-2008, 01:38 PM   #27
everlast -> Thanks, im gonna do that. What exactly did you modify to make it fit? I can sorta guess from the pictures, but i'm not 100%.
The CEL only shows when the car fails to start (in 3rd position, its supposed to be on regardless cause the car's not on). Thanks for clarifying that if the main relay is dead, the CEL wont illuminate. I'm leaning towards fuel delivery problem, but we'll see, it hasen't had any no-start issues since sunday night.
Old 11-11-2008, 01:43 PM   #28
The picture with the ugly cutout is the bottom of the factory bracket. I had to cut it to make the large intake on the bottom of the new pump fit (see the pics of the pumps side by side; the new one has a huge intake).
I strapped it in with supplied tie wraps, used a little fuel hose to attach the top of the pump to the factory bracket and soldered the wires to the bottom of the factory harness.
The last pics were to show the angle of the filter vs the top, because it needs to be on the right angle to be installed in the tank without hitting anything inside the tank.
Honestly, it was really easy.
Old 11-14-2008, 05:04 PM   #29
Ok. So today it didn't want to start again.
Took the rear bench out, took the passenger side fuel pump cover off, i can hear the fuel pump running.
So i checked for spark (really easy on a e30, just rest the spark plug in the front engine hook). Anyway there's spark.
So what should i be doing next? I'm gonna see if i can get someone to come lend me a fuel pressure regulator.
Is there a trick to getting the connector which gives the signal to the injectors to spray out of that plastic box dealy? i can't get it.
Old 11-14-2008, 05:34 PM   #30
Fel
Not Banned
Fel's Avatar
Oh no, it's doing it again huh?
I have no advice, just sympathy. Good luck man... cars can be a bitch.
