Old 11-06-2008, 07:59 PM   #1
scott-[2CZY4
Scott-[2CZY4U]
scott-[2CZY4's Avatar
Send a message via MSN to scott-[2CZY4
is it possible to put a 1 belt setup on a m20
i recently pulled my m20 out of my 325is and i want to change the belts. is it possible to put a single belt setup like modern cars or not. im only running water pump, pwr steer and alternater.. no a/c as i pulled it outa car because it was all damged and i dont need it anyways. any help would be great thnx
scott-[2CZY4 is offline   Reply With Quote
Old 11-06-2008, 08:22 PM   #2
Some dude on e30tech did a serpentine belt conversion on his m20 IIRC. Search there in the M20 forum.
Old 11-06-2008, 08:38 PM   #3
scott-[2CZY4
Scott-[2CZY4U]
thnx man like a 1 belt would be good or even 2 modern belts. i hate the v belts they piss me off hardcore
Old 11-06-2008, 08:41 PM   #4
Here dude, found it for ya. He's adding a supercharger, but you get the idea. http://www.e30tech.com/forum/showthr...erpentine+belt
Old 11-06-2008, 08:59 PM   #5
scott-[2CZY4
Scott-[2CZY4U]
damm thats alot pulleys u see im onli running everything but the a/c so i can get away with 2 belts excatct style belt as his. like run one around pwr str and the other around alternater could work in thoery and lot less mess than his
Old 11-06-2008, 11:12 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I like my $4 vbelts. You can also use a shoelace in a pinch, they are great!
Old 11-07-2008, 12:25 AM   #7
scott-[2CZY4
Scott-[2CZY4U]
ill try my rainbow shoe lace should put a nice touch on it
