Old 10-31-2008, 08:00 PM   #1
Qube
Headlight adjusters...
Damn raccoon broke the headlight adjusters on one side. It's a post 2001 car. Anyone in the GTA that can repair it? If not, what's the best bet for a replacement? I have the LED halo bulb upgrades and it would be great if they can be preserved with aftermarkets...
Old 10-31-2008, 09:14 PM   #2
roachboy
I picked up a set of aluminum adjusters and did a DIY fix at home. You have to bake the headlight in the oven to open it up...it sounds a bit scary but wasn't too hard to do. I ordered a set of adjusters from a guy from bimmerfest. http://www.bimmerfest.com/forums/sho...ight=adjusters
How did the raccoon manage to break the adjuster???
roachboy is offline   Reply With Quote
Old 11-01-2008, 12:45 AM   #3
Qube
Pretty bad smash. Cracked the driver side bumper. Amazingly the carbon fiber lip held the bumper together, otherwise it would be dangling. I'm guessing the impact finally made it give. It's at an acceptable level now... SLIGHTLY low, but tolerable.
Old 11-01-2008, 08:04 AM   #4
Gamite
Gamite's Avatar
you have to take your headlight appart to change them. Time to upgrade to euro clears or if you're going to repair them, remove the amber reflector at the same time.
www.gamite.net
Old 11-01-2008, 03:14 PM   #5
Qube
Where'd you get yours, Gamite?
Old 11-01-2008, 04:31 PM   #6
Gamite
Gamite's Avatar
Umnitza was the cheapest place i could find. Mind you exchange rates suck now
www.gamite.net
Old 11-01-2008, 04:50 PM   #7
Qube
Thanks for checking in!
1. How's the quality on scale of 1-10 (best)?
2. Did you install it yourself , difficult?
3. Halos are bulbs, LEDs, or CCFLs?
4. Did you have to purchase a separate HID kit?
--- What bulb is the low beam?
--- What bulb is the high beam?
--- What bulb are the signals?
Thanks Julian!
Old 11-01-2008, 06:59 PM   #8
Gamite
Gamite's Avatar
1. Quality is excellent, they are OEM Hella.
2. Installed myself, looks hard at first, but is actually pretty easy
3. Halos are OEM bulbs
4. Used my existing OEM Hid's. Low beams are D2S. High beams are H7, signals are your regular single filament signal bulb. Forgot what its called now. Same bulbs as your OEM headlights.
www.gamite.net
Old 11-02-2008, 12:24 AM   #9
Qube
Sounds good. Umn has them for $1020. I'm checking with BMAParts to see what Patrick can do...
FOR VEHICLES WITH
XENON LIGHT
AND
WHITE DIRECTION INDICATOR LIGHTS
S522A=YES
S785A=YES
01 HEADLIGHT XENON RGHT,WHITE TURN INDICAT. 1 09/2000 63126912440
01 HEADLIGHT XENON LFT,WHITE TURN INDICATOR 1 09/2000 63126912439
Old 11-02-2008, 02:20 AM   #10
Gamite
Gamite's Avatar
I think I paid around $960 for them
www.gamite.net
Old 11-02-2008, 08:31 PM   #11
BoostedMX
All Eyes On Me
BoostedMX's Avatar
where can you get the aluminum adjusters at? I don't want to do all that work and put on plastic ones.
Well, I found this http://www.bimmerspecialist.com/cana...1d777d4b01b9c5 but I dont' know if the set is for one headlight or both?
I'll contact them and let you guys know, unless someone already knows.
97 E39 540i
BoostedMX is offline   Reply With Quote
Old 11-03-2008, 11:24 AM   #12
e46it
e46it's Avatar
qube, if you end up buying a new set what are you going to do with the old pair? im looking for a headlight set but broken and not usable> i just need the projector for some other project. let me know.
2004 BMW 325i Touring SGM
2005 Suzuki GSXR 1000|1992 JDM Civic SiR RHD Black
2000 BMW M5 Avus Blue (GONE)
2002 BMW 325i Touring TVM (GONE)
1994 BMW 325i Saloon Black (GONE)
e46it is offline   Reply With Quote
Old 11-03-2008, 04:45 PM   #13
Qube
We'll chat. I have to justify spending the final $1000 this year...
