Old 10-27-2008, 10:57 AM   #1
j2k99
Heat not as hot
Hi all. 2002 325i. I've noticed that the heat doesn't seem to be that hot. When set between 20-22 degrees celsius (68-72 F) and on auto temp, for some reason I feel cool air. However, when I set it to 27C (81F), that's when I start feeling heat.
Any thoughts?
Thanks in advance.
j2k99 is offline   Reply With Quote
Old 10-27-2008, 11:25 AM   #2
piotrek636
formerly Lucky
piotrek636's Avatar
most likely it's the thermostat...
it's gonna sound stupid but your center vent scroll wheel is set to full heat right ? I noticed it has a big impact on the heat / cold temp air pumping out dash... even in the white center zone.
piotrek636 is offline   Reply With Quote
Old 10-27-2008, 11:33 AM   #3
j2k99
yes, i scrolled that thing down to the 3 red dots.
Old 10-27-2008, 11:45 AM   #4
piotrek636
formerly Lucky
piotrek636's Avatar
it must be thermostat then, I had 2 thermostats fail on me in the past.
1. my 1.8T corrado, thermostat stuck closed (was overheating constantly, replaced thermostat... problem gone)
2. my tdi jetta, thermostat stuck open, I could see my temp guage showing lower temp while driving on the highway, it was never hot enough in the car, changed thermostat ... problem gone.
Old 10-27-2008, 12:15 PM   #5
j2k99
Thanks for the response Lucky! much appreciated. I'll have it checked out.
