Old 10-26-2008, 07:40 PM   #1
jamison67
E30 POWER
jamison67's Avatar
Car shaking
well when im driving around 70k is were it starts but when im driving it shaks very rapidly ,i just put new tires on the frt and had them balanced ,if any body can let me now what they think it might be that would be great thanks
jamison67 is offline   Reply With Quote
Old 10-26-2008, 07:47 PM   #2
elroy
hmm shaking would be out of balance but since you did that already i gues that would rule that out. check to see if the tires are on properly, maybe they forgot to tighten them
elroy is offline   Reply With Quote
Old 10-26-2008, 07:52 PM   #3
rims tires on straight/tightened/balanced,
ball joints, control arms, alignment.
that's where i'd start.
Old 10-26-2008, 07:59 PM   #4
5thseries
biggerthen3
Check the drive shaft..
5thseries is offline   Reply With Quote
Old 10-26-2008, 09:14 PM   #5
e30_kid89
The Afro-stig
e30_kid89's Avatar
probably the driveshaft center support bearing and/or the driveshaft u-joints giving out.
Old 10-26-2008, 09:44 PM   #6
Nguyen_E30
0011 0001 1000
hard to really diagnose the problem online. best to bring it to a mechanic and get an opinion. this could be due to a lot of things including a broken engine mount and what is mentioned above. just bring it to a mechanic and they'll tell you. thats your best bet.
Nguyen_E30 is offline   Reply With Quote
Old 10-26-2008, 10:15 PM   #7
BmW1819
if u just put tires on and it just started to happen than it's either the rims are bent or tires are shit but if it was happening before
Old 11-02-2008, 06:44 PM   #8
Ej_Red
Like mentioned before, if it started after you put new tires on then tires/balance is your problem. Otherwise, it could be anything that causes shimmy condition. Where do you feel the vibration, steering wheel or driveline? Check for worn out ball joints, other suspension components. Could be seized u joint on the driveshaft.
Ej_Red is offline   Reply With Quote
Old 11-02-2008, 07:08 PM   #9
slimjim
Almost Sideways
if it was the center support bearing, u would feel the vibration in lower gears where there is more torque.....ask me how i know
oes the vibratngo away when u give more gas? how about when u press the clutch down to drop the rpms, does it still vibrate?
are they the same rims with the new tires or new rims 2?
Old 11-02-2008, 09:43 PM   #10
iignite
did it shake before you got your tires mounted? if so, bring them back to double check for improper balancing. If not, check all above posts
We would need more information on what is shaking and at what speeds, such as steering wheel shaking, shaking when braking, off the highway, heavy acc, etc..
iignite is offline   Reply With Quote
