Old 10-23-2008, 06:44 PM   #1
andicanada
andicanada's Avatar
oil feed and return for Turbo S52
Hey guys i was wondering what would be the best place for the oil feed and oil return on s52 also what size hose and conector should i run !?
THANKS FOR ANY HELP
BYE ANDRE
Old 10-23-2008, 10:24 PM   #2
SamE30e
SamE30e's Avatar
Oil pan.
What size turbo.
91 318is - M50NV (gone)
85 - 325
SamE30e is online now   Reply With Quote
Old 10-24-2008, 07:42 AM   #3
andicanada
andicanada's Avatar
i dont know yet what kinda turbo i want as i wanne get the engine done first and then do the turbo.
the compression is 8.5:1 so for the return i go in the oil pan thats clear so fare but from where do you guys take the oil ? i think there are 2 options drilling and tapping the block or drilling and tapping under the oil filter housing
what would be better
Old 10-25-2008, 10:43 AM   #4
_DIESEL_
_DIESEL_'s Avatar
I would just get a T adapter and screw it on the oil filter housing where your oilpressure sensor is thats the easy way no driling nothing.
_DIESEL_ is offline   Reply With Quote
Old 10-25-2008, 03:23 PM   #5
FuryriderX
cra.iX.y
FuryriderX's Avatar
QFT
Old 10-26-2008, 11:26 PM   #6
PedroBMW
Hooked on Boost
PedroBMW's Avatar
+1 I agree with the oil pressure sender location.
I used this T from TRM its a quality peice but not cheap @ $30 it gives you a 1/8"NPT so then I just used a 1/8"NPT to -4AN fitting --> http://www.racersmarket.net/catalog/...products_id=43
For the drain, just tap the oil pan and go. I used a -10AN to 3/8" fitting and tapped it into the pan. Easiest way to go is to do it with the oil still in so that you don't have to pull the pan, if you do pull the pan then I'd just do a welded bung.
The problem you'll probably have depending on your manifold + turbo choice is that the turbo is so low that you'll have a very poor gravity drain. I think I'll be buying a scavenge pump over the winter to make mine a bit better, my turbo sits lowso I have maybe 1.5" of drop, thats it. When you buy your drain fitting for your turbo, I'd try to find the lowest profile one possible, it'll at least make the best of the situation.
Old 10-27-2008, 11:13 AM   #7
You drilled and tapped the oil pan and didn't pull the pan? Wouldn't that leave, say, a bunch of metal chunks in your oil? :?
Old 10-27-2008, 07:09 PM   #8
e30_kid89
The Afro-stig
e30_kid89's Avatar
Well im thinking the idea is while you're drilling with oil still in the pan once you gone through the oil in the pan will come rushing out taking w/e metal flakes with it.
Old 10-27-2008, 07:11 PM   #9
What about the ones that don't? As much as I'd like to use this method, that sounds like a bad idea.
Old 10-27-2008, 08:33 PM   #10
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Well the idea is that as the oil came spooling out, the shavings came with it. truthfully I have no proof that there are no shavings inside other than the fact that my cars runs : ), I also ran 3 Liters of fresh oil threw the new hole I made (flush anything at all) before actually filling the car with oil again. I recommend pulling the pan, I'm sure its less risky, however I do know many people have done it my way.
Old 10-27-2008, 10:28 PM   #11
///tyron
///tyron's Avatar
hows your car running? are you running an gt30r or 35r?
///tyron is online now   Reply With Quote
Old 10-28-2008, 05:49 AM   #12
PedroBMW
Hooked on Boost
PedroBMW's Avatar
neither, I'm running a t3/t04e 60 trim with 0.82 hotside.
Old 10-28-2008, 10:10 AM   #13
Interesting.
