10-20-2008, 06:00 PM
#1
Car: bmw 328 is
supercharged e36 m3
hey guys, my brother has an m3 he just bought that has an active autowerk supercharger kit running 8- 10 psi. its running too fat/rich and the back bumper gets covered in shit. how do i know if this kit came with software, how do i check etc etc.
also, the car is leaking every colour possible lol oil, and very small amounts of anti freeze. any ideas on where these leaks r coming from? i replaced the oil pan gasket and the leak stopped and came back 2 weeks later, it could be it again. i just want to know from the experienced ppl here with boost on what is common etc. YOUR HELP WOULD BE VERY MUCH APPRECIATED GUYS!!!!
thanks.
10-21-2008, 12:41 AM
#2
Car: Vortech m3
Try matching the dripping colors with the colors in the each of the reservoirs? aka power steering, engine oil, tranny, diff, brake, etc.
Hope he got a good deal as the car sounds a little hurtin'.
10-21-2008, 02:31 PM
#3
Car: who knows I lost track
thanks.
How do you know if this kit came with software ??? Of coarse it came with software. Take out the DME take off the cover and you will see if there is an AA chip in it. What are your AFR reading thought out the RPM range. Theres no way to adivse you what to do until you give us numbers.
If your leaking coolant check to see where the coolant is coming from by popping the hood. Could be hoses, thermostat, waterpump.
Personally unless you know the person and there driving habits and how they maintain the car buying a forced induction car is a tricky game.
Hope this helps good luck
Its all about rolling in the X5 !!!
10-21-2008, 03:24 PM
#4
Car: 93 325Is, 95 Superch
I had the same problem. It was a vaccume leak.
10-21-2008, 05:34 PM
#5
Car: bmw 328 is
the coolant leak i cant tell where its coming from all i know is that it is dripping off my oil pan before my oil leak occured...as for the oil leak, oil is all over, hard to tell where the oil leak is coming from until i pressure wash the underneath of the car...i was just wondering..when a boosting an m3, is there any common leaks that will occur and if so from where? given what i am leaking (oil, anti-freeze). as for the AFR readings, pretty much anywhere between 12:0 to 13:9 from idle to redline, very rich. any more help would be greatly appreciated guys!!
10-21-2008, 05:35 PM
#6
Car: bmw 328 is
Trouble65, what problem did u have that was a vacuum leak?
10-21-2008, 09:11 PM
#7
There is so many and any one of those could cause a problem.
10-22-2008, 10:51 AM
#8
AMG ETR
Car: S/C S54B32
why don't you just take it to a pro and have them look at it and tell you exactly whats wrong with it?
10-22-2008, 04:53 PM
#9
Car: Supercharged M3
If my short term fuel trim is 17.4 for bank one and 23.5 for bank two dose that mean I have a vacume leak?
10-22-2008, 05:08 PM
#10
If my short term fuel trim is +17.4 for bank one and +23.5 for bank two dose that mean I have a vacume leak? I also have no low end torque below 4000 RPM. What is the problem? Can someone help me. Sorry but on the I forgot to mention that I am running 15 PSI of boost on my car with a Vortech V2 blower.
11-10-2008, 08:12 PM
#11
Pole busted to boosted.
Car: 97 boosted m3.
15 psi ^^ give some detail on this set up.
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
11-11-2008, 11:19 PM
#12
Car: AA S/C E46 M3
What about spark plug gap?  (just playin big guy) - See you next week...let me know what day...so I wont be there. lol
To check if it has AA or any other tune like 'greekthang' said check the DME. If it is OBD2, you dont need to open it up since it is a software D/L so the tuner ususally slaps a sticker on the DME. If your car is OBD2, I think I know why your oil pan was leaking (and might still be). Anyways, give me a call and we can set something up to check it out. By the way, were you ever driving besides a yellow and also a black E36 on the 401 W few weeks back?
Also blown M3....what crank/blower pulley set up are you running? You must be spinning the blower pretty high to get that boost....like JMW said whats the details on your set up if you dont mind me asking.
Authorized Ontario dealer for Active Autowerke|VF-Engineering| AFE| Bilstein Suspension| H&R Suspension| KW suspension| Brembo Brake Systems| Stoptech| - Call us for the best pricing
11-12-2008, 09:00 AM
#13
Well I have sorted out some of the problems the car is runing a little bit better. but the LT fuel trims are now both at 11.7, Dumping in extra fuel for no reason and I have no low end torque. The set up I am running is a Vortech V2 which was upgraded to the SI trim from the s trim. The SI trim is capable of spinning at 55,000 RPM not 50,000 like the s trim. I am running a 6" crank pulley and a 3.125 blower pulley. It is only hitting 15 LBS at readline.
11-14-2008, 07:09 PM
#14
Car: AA S/C E46 M3
Interesting, is the set up your running a kit or custom? What tune...is there a scaler box or modified MAF wiring?
11-14-2008, 11:31 PM
#15
This is an RMS stage 2 kit Vortech V2 with aftercooler and the tunning is done by Karl at AA. M50 Manafold, 42 Lb injectors,2 1/2 exhaust with no cats or resonators, porchse HMF. The wiring for the MAF has been modifed.
